A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Squeeking noise steering
Old Sep 19, 2023 | 09:22 AM
Alexxelax's Avatar
Default Squeeking noise steering
Hi, please help me identify the noise I recently got.
It is like a rubbering squeeing noise when turning steering wheel.
File Type: mpg
Old Sep 19, 2023 | 09:48 AM
A6Gary's Avatar
Is the noise occurring in the interior or exterior? Can't tell from your MPG file.
Old Sep 19, 2023 | 11:11 AM
Alexxelax's Avatar
It sounds from inside the car. I have not heard anything from outside, however the noise is still there when car is turned off, So I do not think it is a PS problem or belt.
Old Sep 19, 2023 | 12:09 PM
das60's Avatar
FWIW, it a Toyota this is a common issue with a little rubber bushing where the steering column penetrates the firewall.
This post may provide insight starting at post #3, it is Audi specific and focuses on an intermediate shaft in the steering column.
Old Sep 20, 2023 | 02:30 AM
Alexxelax's Avatar
I will check to see any rubber but the noice came when I changed tires, however this is not a tire noise, it is something with the steering wheel, Maybe spraying some wd40 around joints to see if I can locate the problem.
Old Sep 28, 2023 | 07:18 AM
Alexxelax's Avatar
Solved
As das60 mentioned, rubber boot on firewall stopped making noise after greased up. I also greased the steering shaft joint. No more noise.
xandermacha
A4 (B8 Platform) Discussion
Apr 11, 2023 02:13 PM
Vrbaa
Aug 17, 2022 09:37 AM
TomLeeChan
Aug 4, 2013 07:55 AM
esanmiguel
Jan 29, 2007 03:10 PM
sbs4guy
Jul 31, 2002 10:52 AM
