A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Wipers no signal - not working
Old Sep 20, 2023 | 04:27 AM
krisis32's Avatar
Default Wipers no signal - not working
Hello there,
I have an issue with audi wipers - not working after car was stationary for about a week.
Code from vcds:
00908 - Control Module For Wiper Motor
004 - No Signal/Communication
At first I thought maybe the wiper arm and control module was dead so I switched to a friends one, but same error code comes up.
In dash I have windshield with a red lightning across.
Did fault reset, but error stays.
Maybe someone knows the diagram for the wiper motor connector, to test the voltage? If that's not the issue - could it be the J519 module?
Old Sep 20, 2023 | 08:12 AM
AudiAllTheWay's Avatar
Community Builder
Check the fuse
Old Sep 20, 2023 | 10:55 AM
krisis32's Avatar
Forgot to mention, that was the first thing I did - checked fuse 38, but it was fine. Just to be sure, replaced with a different one, nothing changed.
Old Sep 22, 2023 | 12:11 PM
krisis32's Avatar
Maybe someone in future will find this useful.
Resolved the issue by unplugging T32c connector from J159 module. Ran a wire test with multimeter for pin 27 back to the same wire (purple/white) that connects into j400 module. Then ran test for current and both red/white and purple/white wire showed current which can't happen since purple/white is unplugged.
Then removed this cover (fuse e box) and deeper under there was a bit of water leak which caused a short circuit. Dried it out, cleaned drain pipes, sealed off the cover and now there is no error anymore. Wipers work now.
Old Jan 13, 2024 | 12:38 AM
Ado 65's Avatar
Default Front wipers not working
  1. Hi I have the same wiper issue, going to try your fix if I can follow what you did!
karl kane
14
Apr 15, 2024 12:09 PM
Bfb1963
May 3, 2022 01:13 PM
Mario Barros
Aug 21, 2020 05:42 PM
E_S81
Audi 100 / A6 (C4 Platform)
Oct 28, 2006 08:48 AM
Produce
Jul 9, 2002 02:40 PM
