2008 A6 4.2 cooling fan staying on continuously after shut off
I also saw some articles about two coolant emp sensors. One for the fans and one for the guages. I went through a lot of measuring blocks in VCDS and only saw the one for the G62 temp sensor. Woudl definitely appreciate some help on this one.
Other symptoms I noticed today.
When I first ocnnected the battery this morning, the fan came on immediately.
I put a battery tender on the battery overnight (it was disconnected, otherwise the fan would have run forever I would guess). I connected it to move the car this evening. It ran for less than 3 minutes. I parked it and didn't disconnect the battery. I waited and it came on after ~10 minutes.
It will go off if I open the door or start the car.
I have the AC system off.
Maddening.
And also looked in my owners manual and there is an index entry for Radiator fan. It says:
The radiator fan switches on automatically by itself (in italcs for emphasis even)
But also foes on to say the radiator fan is driven by the engine via the v-belt (not true for the 4.2).
An auxiliary fan switches on and off depending on the coolant temperature and other vehicle operating conditions (thanks for the specific Deiter)
After you switch the engine off, the aux fan can continue running for up to 10 minutes - even witht he ignition off. It can even switch on again later by itself if,
- The temperature of the engine coolant rises due to the heat build-up from the engine in the engine compartment or
- the engine compartment heats up becuase the vehicle is parked in intense sunlight
This points to either the coolant temp sensor or some control unit that I have not yet identified (unless its the power module)
Looked at my VCDS scan again and I may have overlooked this one too quickly:
009488 - ECM/PCM Power Relay Sense Circuit
P2510 - 002 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 274364 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 59.0∞C
Temperature: 40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
This is the mileage when this first happened. I definitely did not have any battery disconnects prior to this. The plot thickens....
One of several butt connectors
The water is the shiny looking piece at the middle right
Cleaned plenum cover
Off topic and might be the lighting but is the brake fluid dark color and maybe turning green? If so then the hydraulic system needs a flush and afterwards the pedal will be less spongy.
