A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Intake Manifold Tuning Control Solenoid Valve Location?
Old Oct 5, 2023 | 07:40 PM
Tillyy's Avatar
Default Intake Manifold Tuning Control Solenoid Valve Location?
Hi all,
First time poster on this forum.
I own a 2009 Q5 with a 3.2L engine - somewhat uncommon in the Q5. As a result of limited years in production, there are not so many owners with the 3.2L. So I thought I may get a better response on this forum since A6 used the same engine.
A few weeks ago I noticed reduced acceleration and MPG.
After a scan, the code P2070: Intake Manifold Tuning (IMT) Valve Stuck Open Bank 1 was present. Cleared it and it reappeared. I've inspected vacuum lines for leaks and the IMT flap. All seems good.
Based on a few posts across the boards, it appears a defective vacuum control valve (037906283C) is a common issue for this code.I ordered the part but had a question regarding it's placement.
Question: Where's the location of this specific valve that controls the IMT? At the front or rear of the engine?
Based on the drawing below it appears there's 2 or 3 of these control valves across the engine bay. (#32 front, #32 rear, #37 front?)
Thank you for any help.
Source: Audi Q5 (2009 - 2012): Vacuum system. Intake system.
Old Oct 6, 2023 | 09:12 AM
A6Gary's Avatar
When the same DTC came up on my 2006 A6 Avant, the cause was a defective vacuum chamber on one of the lower intake manifolds. To correct, I had to purchase a complete lower intake assembly. From your pic, I believe #32 and #37 are the electrical valve that supplies the vacuum to the chamber that activates that IMT.
Old Oct 6, 2023 | 07:33 PM
Tillyy's Avatar
Thanks for the input. The front control valve (037906283C) does actuate the intake manifold tuning actuator as removing the electrical connector created a new code P0660 - Intake Manifold Tuning Control Circuit.
After replacing the front control valve (Pierburg - 037906283C), the code P2070 was eliminated. Glad it was a relatively cheap repair this time.
Front control valve solenoid (037906283C)
Pierburg - 7.22880.01.1 Valve Solenoid (037906283C)
Old Dec 30, 2025 | 02:38 PM
das60's Avatar
Thanks, I was getting the P2070 code and tested the solenoid with a low voltage source to hear no characteristic click. To replace I loosened all 12 IM screws and removed the vacuum lines plus connector. I then raised the IM an inch or so in front. It took me a bit to pinch the tabs correctly but the old solenoid came out and the new one went in easily. Now I have to stop making excuses and get to the inner CV boot.
grkmspr
11
May 28, 2025 08:47 PM
melon92
A4 (B8 Platform) Discussion
Mar 3, 2021 04:32 PM
