A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
A6 2010 Performance modes
Old Oct 10, 2023 | 05:41 AM
AndreasB's Avatar
Default A6 2010 Performance modes
Hi I am pretty new to this and some of the people I k ow are telling em I should Mode my car. It is a 2010 A6 avant 3.0T. I am wondering if anyone knows what modes I should add to make it a touch more sporty and what brands to look at?
Old Oct 10, 2023 | 08:13 AM
AudiAllTheWay's Avatar
Community Builder
The first recommendation is run a bottle of high quality direct injection fuel system cleaner thru a tank of premium fuel.
What is the mileage and maintenance history? Maybe time for some systems service such as plugs, oil separator, belts / idlers / tensioners, injectors, chain job, trans fluid and filter service, brakes, etc. Ideally get the engine running well with zero DTC’s.
Power increase usually starts with a Stage 1 ECU flash and if you want more then increase the blower pulley ratio with either a larger crank pulley or smaller blower pulley or both. Do some research as there are trade offs. Pulley ratio tops out around 3.3 unless you get into porting the blower and larger throttle body. Increasing the pulley ratio can shorten life of critical parts. Increasing the supercharger boost creates more heat and if the extra heat is not managed then the stock cats can literally melt which leads to aftermarket exhaust systems etc. Performance upgrades are all relative and you’re going to pay more to play more especially with the 3.0T.
There are a lot of vendors to consider and JHM is one good example:
https://jhmotorsports.com/jhm-ecu-an...6-a6-3-0t.html
beep-beep
Nov 10, 2021 05:11 AM
chihashu
Dec 1, 2004 12:01 PM
ayap
Audi allroad
12
Feb 15, 2004 03:37 PM
Kaching
9
Dec 5, 2000 04:33 AM
Rob O
Jul 19, 1999 05:41 AM
