Replacing drivers door for C6 avant
Thanks!
Thanks!
What is not identical is if you dont buy exact trim package is inner shell and wiring.
If you have Bose - its different then regular
If you have keyless - its different.
Ive done the swap on mine and it was an incredible pain in the *** because I had to swap everysingle wire down to the bare metal because mine has keyless and bose.
Rear door also match from sedan, but you need to swap the top glass portion from your old doors.
Also mayor pain in the *** but doable. Done those as well.
Also, grab your Paint code from the trunk, and compare with the car you are getting the doors from, so you dont need to paint them.
Do you have the advanced key with push button start? If you don't, and you get a door from a vehicle that does, then you will need to swap the harness. You can leave the aerial antenna, door handle touch sensor and push button in place and just not connect them to your old harness, it's up to you.
Make sure to watch a video or look at a diagram for where the screw locations are on the door trim, removal isn't too bad as long as you get all of the screws out first :-)
As others have said, no difference between the Avant and Sedan doors. What I have found is that coloring from the same model year seems to match better (for same paint code). Maybe this is because of paint fade, maybe it's because of different batches of paint, I don't know, but either way it's better than a door with rust holes. While you have the trim off, make sure to check the water drains in the door, I think my rusted ones were the result of those drains getting plugged up and salt water accumulating, accelerating the rust. Once it starts rusting, the rust/paint flakes plug it up even worse.
My A6 is quartz grey, and I found another that looked the same, but looked little off, and my eyes were right, it was a different paint code.
There was a time when I wanted to set up one side of my garage with the ability to put up plastic and do "pro" grade painting on my cars.... Then I started reading about all of this and decided that I will stick with rattle cans forever LOL
I have personally swapped dark blue doors on a C5, and medium grey on C6, both matching Paint code, there is no chance you can tell they were not originally on the car.
And let me tell you why as well, a certain paint code is in use for maybe 2-3 years max, even if that much.
Even if car is garaged over night, night is not the time that will "age" the paint. Its daytime driving and sunlight.
