AFS headlight self-leveling issue
Anyway, I have problem with self-leveling of AFS headlighs.
When I switch on xenon headlights, they do not perform self-leveling procedure, like they always did before.
There are no DTC, no blown fuses, headlights works ok during adaptation procedure on VCDS (projectors go down, up, left, right, spread and center focus and follow steering wheel) but there is no self-leveling procedure when I turn the lights on.
Fuse for headlight washers was out, creating constant DTC which was annoying to me, so I coded headlights to option 4 in central electrics and “maybe” (not sure) coded something else somewhere on gateway in order to have it properly coded out, but I can’t recall for sure what was that second step or even that second step had really happened. If it did happened, I simply can’t figure it out what was it related to and I was looking for two days on entire gateway what else “might be” additionally coded out, with no success.
Meanwhile, I put back the headlight washer fuse, disconnect and plugged the pump hoses to stop it spraying over the hood, coded back to AFS headlights with washer system (option 3), but something is missing out and I can't figure it out what.
Any help would be much appreciated.
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Control Module Part Number: 4F0 910 357 F HW: 4F0 907 357 F
Component and/or Version: AFS 1 H01 0020
Software Coding: 0000016
Work Shop Code: WSC 02325 758 00200
Additional Info: 4F0941329D AFS-Modul links H01 0010 4F0941329D AFS-Modul rechtsH01 0010
VCID: 295948A380F92BDBBC-807C
1 Fault Found:
02071 - Local Databus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 293544 km
Time Indication: 0
Date: 2023.10.26
Time: 07:23:24
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 293544 km
Time Indication: 0
Date: 2023.10.26
Time: 07:23:24
02071 - Local Databus: No Signal/Communication
Possible Symptoms
- Control Modules connected to Local Databus not functioning
Possible Causes
- Wiring/Connectors from/to Control Modules in Local Databus faulty
- Control Module in Local Databus faulty
Possible Solutions
- Check/Repair Wiring/Connectors from/to Control Modules in Local Databus
- Check/Replace Control Module in Local Databus
Special Notes
- When found in Combination with 00153, check special notes.
- When this fault code is flagged, it is important to check other control modules for fault codes. Different slave modules for different systems may be on the same bus (wire), thus one failed item causes several other items no longer perform to factory design.
Your software coding seems correct, since I also have Bi-Xenon and have the same coding:
Part No SW: 4F0 910 357 A HW: 4F0 907 357 A
Component: AFS 1 H03 0010
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 A
Component: AFS-Modul links H05 0010
Subsystem 2 - Part No: 4F0 941 329 A
Component: AFS-Modul rechtsH05 0010
No fault code found.
Do you have any other faults? It seems like one bad component can drag down things downstream as indicated in the Ross-Tech Wiki page linked.
I think I know the suspect here, this might be the right side headlight wiring below the projector. Someone has been there before...
Funny thing is, projectors are not dipped down, neither one.
Problem is, wires that I'm able to observe visually inside the headlight looks brand new, so I've hit the wall here.
Does the AFS modules tends to go bad, offten?
So when you do a full scan that is the ONLY fault in the entire system? I mean, I get like a fault in my XM radio cause I don't have it activated (obviously causes no issues with the system as the MOST loop is still active).
I ask because a lot of the wiki points fingers at other controllers possibly getting in the way of communication.
I see that headligh was opened before, but on left headlight someone had cut off bottom portion to access the wirings (my mistake).
This is the only DTC in electrical compartment, tho I have 2 DTC for B1 and B2 O2 sensors (intermittently). Something like short to ground, etc. Don’t have access to VCDS to confirm exact DTC.
MOST is ok, I took a test many times..
If you don't have access to VCDS, how did you post the earlier scan results?
I don't think the O2 sensors would be on the same circuit as the headlights, but shorts can cause havoc in a system. Try and get a full scan done wherever you got the original results and see anything else that is acting up.
There are no electrical DTC except this one 100%, but I’ll double check again. There was none few days before.
