2008 S6 engine wiring diagram
Removed untake and did carbon cleaning. 2 plugs I cant locate. One, forward near cooling fans close to flap cervo, the other passenger side near air intake.
Wire colors attached. Thanks
The 3 wire on the front vertical face of the intake is likely for the flap actuator that has been removed from your intake. Can see where the actuator shaft is plugged with a bolt and blue sealant on your intake. Do you know if your intake has the flaps abandoned in place, flaps removed or flaps glued in long runner position?
Some folks who modify the center intake flaps leave the actuator in place and electrically connected but actuator mechanical arm removed for no DTC. There is no position sensor feedback for the long / short flap position so the ECUs will never know, although obviously there is a notable performance difference.
The label terminology may not be exactly correct but hopefully conveys the concept…
