A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Engine/trans. pulled & back. Help!
Old Nov 17, 2023 | 05:17 AM
jmaddog's Avatar
Default Engine/trans. pulled & back. Help!
Back Together and I need help S6-C6 2007I started my project five years ago. Right after I flattened the right doors like pancakes and landed like a helicopter in the woods. Shes totalled. If you own an S6 C6 the ( I am very proudly an ASE gold autobody I am in the grapevine with insurance company s shops those who know know) So i just happen to have a 05 S-line C6 sitting at home thank you for that 2g steal! Blown cam. Donor car UP! Fixing the body n suspension metal and plastics talk my language. So I gutted the cats moved my 2nd dwnsrtm 02 on a lil j-line youll see. Abd J-lined the 1st bank down from the smaller tincan cat. Yes 3" straight-X piped back bye, bye, spare and relocated canister lines ect. Behind Rr whl. (Skip to Car **** pics included if you must see the custom frt bumper “back is in the works” and hood custom satin black w/satin blk rims red accents but come back and help plz!??) have an obd11 for diagnostics . She is pretty all the bells n whistles are not on her yet. But needed to see what came from a test run. SO. I cleared he codes she started right up after a couple turns . No real codes came back. ,tpms,i put leds in and gotta fix that. Hdlghts are from an s-line need some council Np. Shat like that. I can not tell you my excitementat this point. Five years!! (Oh i did the transmission full maintenance change fluids filters gasket) The ran her. She first of all sounds mean as hell and the X pipe really helped with the sound. She ran rough a bit at first but once to warm and check through her system she got better. Real good! I had tears in my eyes at this point. This journey was incredibly difficult and challenging to the point of insanity. This car saved my life she will live. Did the basic and backed out. Left her five year operating table . NP what so ever. Nice into drive then all **** broke loose!! Acted like limp mode no codes. Jumped in to and out of gears. Got home with np but she stalled and gave up taking care of me got me back once again. Love my Audi. Hooked her up obd11. Where do I start at even. Any help please. OBDeleven data log Date: 2023-11-14 09:57 VIN: WAUGN74F87N140864 Car: Audi S6 Year: 2007 Body type: Saloon Mileage: 175460 KM --------------------------------------------------------------- 00 Steering Angle Sensor Trouble codes: No trouble codes found --------------------------------------------------------------- 01 Engine System description: 5.2L V10/4V FSI Ş Software number: 4F1910552A Software version: 0040 Hardware number: 4F1907552 Long coding: 01050009190F0160 Trouble codes: P1653 - Read DTC memory of ABS CM Implausible signal static P0190 - Fuel Rail Pressure Sensor “A” Circuit Upper limit exceeded static P0201 - Cylinder 1- Injector Circuit No signal/communication static P0205 - Cylinder 5- Injector Circuit No signal/communication static P0202 - Cylinder 2- Injector Circuit No signal/communication static P0203 - Cylinder 3- Injector Circuit No signal/communication static P0204 - Cylinder 4- Injector Circuit No signal/communication static P1923 - Check DTC memory of Engine Control Module (ECM) 2 Implausible signal static --------------------------------------------------------------- 02 Transmission System description: AG6 09E 5,2 FSI USA Software number: 4F2910156M Software version: 0030 Hardware number: 09E927156C  Serial number: 0103286 Coding: 0000002 Trouble codes: U0128 - Lost Communication With Brake System Control Module static --------------------------------------------------------------- 03 Brakes System description: ESP 8.0 quattro H05 Software number: 4F0910517P Software version: 0070 Hardware number: 4F0614517P Serial number: 00000000000000 Coding: 0020920 Trouble codes: 00473 - Electronic parking brake control module -J540 No signal/communication static 01826 - Steering angle sensor, voltage supply terminal 30 static --------------------------------------------------------------- 05 Keyless System System description: FBSAUDIC6 ELVSG H01 Software number: 4F0910852A Software version: 0030 Hardware number: 4F0905852C Hardware version: 242 Serial number: 10601200710564 Coding: 0000007 Subsystems: System description: FBSAUDIC6 EZS H45 Software number: 4F0910131L Software version: 0080 System description: FBSAUDIC6 KSG H27 Software number: 4F0910335 Software version: 0080 System description: FBSAUDIC6 IDG H01 Software number: 4F0910220G Software version: 0053 Trouble codes: No trouble codes found --------------------------------------------------------------- 07 Display System description: Interfacebox H43 Software number: 4F0910732D Software version: 4140 Hardware number: 4E0035729A Serial number: 361CH077511713 Coding: 0010003 Subsystems: System description: Bedienteil MMIC6H01 Software number: 4F0910609E Software version: 0060 Trouble codes: No trouble codes found --------------------------------------------------------------- 08 Air Conditioning System description: KLIMABETAETIGUNGH30 Software number: 4F0910043A Software version: 0020 Hardware number: 4F1820043AG Serial number: 00000030605327 Coding: 0524330 Trouble codes: 00797 - Sunlight photo sensor Open circuit/short circuit to ground static --------------------------------------------------------------- 09 Central Electrics System description: ILM Fahrer H17 Software number: 4F0910279J Software version: 0240 Hardware number: 4F0907279A Serial number: 4F0907279 Coding: 0115123 Subsystems: System description: Wischer AudiC6 H05 Software number: 4F1910113C Software version: 0210 Coding: 0064784 System description: REGENLICHTSENSORH13 Software number: 4E0910557A Software version: 0090 Coding: 0146221 Trouble codes: 02745 - Left daytime running lamp bulb Open circuit static 02746 - Right daytime running lamp bulb Open circuit static 01496 - Left fog light bulb Open circuit/short circuit to B+ static 01500 - Right fog light bulb Open circuit/short circuit to B+ static --------------------------------------------------------------- 0E Media Player System description: MP3-Changer H44 Software number: 4E0910110C Software version: 0350 Hardware number: 4E0035110A Hardware version: 000 Serial number: AUZ5ZBG3194000 Trouble codes: 02261 - Data medium Faulty static --------------------------------------------------------------- 0F Digital Radio System description: SDAR SIRIUS H06 Software number: 4E0910593H Software version: 0080 Hardware number: 4E0035593D Serial number: AUZ4Z7G0062776 Trouble codes: No trouble codes found --------------------------------------------------------------- 11 Engine 2 System description: 5.2L V10/4V FSI Ş Software number: 4F1910552A Software version: 0040 Hardware number: 4F1907552 Long coding: 01050009190F0160 Trouble codes: P1653 - Read DTC memory of ABS CM Implausible signal static P1536 - Bank2, camshaft adjustment Open circuit No signal/communication static P0019 - Crankshaft Position-Camshaft Position Correlation Bank 2 Sensor B Upper limit exceeded Intermittent --------------------------------------------------------------- 15 Airbag System description: 7G AIRBAG AUDI8RH30 Software number: 4F0910655K Software version: 0400 Hardware number: 4F0959655D Serial number: 003BMD0105U% Coding: 0014151 Subsystems: System description: BF-Gewichtsens. H02 Software number: 4F0910339A Software version: 0050 Trouble codes: 01738 - Driver’s Front Airbag Crash Sensor Faulty Intermittent 00532 - Supply voltage Lower limit not reached Intermittent 02095 - Component protection active Intermittent 01222 - Side airbag crash sensor Frt. pass. side Open circuit/short circuit to B+ Intermittent 00655 - Belt tensioner igniter (frt. pass. side) Upper limit exceeded static 00003 - Control module Faulty static 01221 - Side airbag crash sensor Driver side Open circuit/short circuit to B+ Intermittent 01639 - Side airbag crash sensor, behind frt. pass. side Implausible signal static 01638 - Side airbag crash sensor, behind driver side Implausible signal static 01638 - Side airbag crash sensor, behind driver side Short circuit to ground static 01639 - Side airbag crash sensor, behind frt. pass. side Short circuit to ground static 01590 - Igniter for battery interrupt Upper limit exceeded static --------------------------------------------------------------- 16 Steering Column System description: Lenksäulenmodul H08 Software number: 4F0910549 Software version: 0230 Hardware number: 4F0953549A Serial number: 90026070690438 Coding: 0012141 Subsystems: System description: Lenkradmodul H07 Software number: XXXXXXXXXXX Software version: 0090 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dashboard System description: KOMBIINSTR. M73 H20 Software number: 4F0910930C Software version: 0170 Hardware number: 4F0920980Q Hardware version: H20 Serial number: 5H337P837 Coding: 0081227 Trouble codes: 00473 - Electronic parking brake control module -J540 No signal/communication static --------------------------------------------------------------- 19 Gateway System description: J533__Gateway H06 Software number: 4L0910468 Software version: 0040 Hardware number: 4L0907468 Serial number: 0900B0730301CF Long coding: F5D5DCF7307A02 Trouble codes: 01044 - Control module incorrectly coded static --------------------------------------------------------------- 36 Driver Seat System description: Sitzmemory FS H04 Software number: 4F0910760 Software version: 0050 Hardware number: 4F0959760 Serial number: 00000000896400 Coding: 0082954 Trouble codes: No trouble codes found --------------------------------------------------------------- 37 Navigation System description: MNS US H48 Software number: 4E0910888D Software version: 0970 Hardware number: 4E0919887L Serial number: 381CL077520256 Trouble codes: No trouble codes found --------------------------------------------------------------- 42 Driver Door System description: TSG FA H12 Software number: 4F0910793E Software version: 0120 Hardware number: 4F0959793E Serial number: EdU�000000000 Coding: 0051947 Trouble codes: No trouble codes found --------------------------------------------------------------- 46 Comfort System System description: Komfortgeraet H22 Software number: 4F0910289G Software version: 0170 Hardware number: 4F0907289G Serial number: 01037167400000 Coding: 4618269 Subsystems: System description: LIN BACKUP HORN H03 Software number: 1K0951605C Software version: 1301 Trouble codes: 02199 - Right tail light bulb 2 Open circuit/short circuit to ground static 01502 - Left rear fog light bulb Open circuit/short circuit to ground static 01504 - License plate lamp Open circuit/short circuit to ground static 01134 - Alarm horn Electrical error in circuit static 02198 - Left tail light bulb 2 Open circuit/short circuit to ground static --------------------------------------------------------------- 47 Sound System System description: DSP-High C6 H10 Software number: 4F0910223J Software version: 0240 Hardware number: 4F0035223G Serial number: 00000000018368 Coding: 0000026 Trouble codes: No trouble codes found --------------------------------------------------------------- 4F Central Electrics 2 System description: ILM Beifahrer H10 Software number: 4F0910280 Software version: 0080 Hardware number: 4F0907280B Hardware version: — Serial number: 00000000044252 Coding: 0012014 Trouble codes: No trouble codes found --------------------------------------------------------------- 52 Passenger Door System description: TSG BF H12 Software number: 4F0910793E Software version: 0050 Hardware number: 4F0959792E Coding: 0051947 Trouble codes: No trouble codes found --------------------------------------------------------------- 55 Headlight Regulation System description: AFS 1 H01 Software number: 4F0910357F Software version: 0020 Hardware number: 4F0907357F Coding: 0000255 Subsystems: System description: AFS-Modul links H02 Software number: 4F0941329B Software version: 0020 System description: AFS-Modul rechtsH02 Software number: 4F0941329B Software version: 0020 Trouble codes: 01539 - Headlights were not adjusted no or incorrect basic setting/adaptation static 01042 - Control module not coded static --------------------------------------------------------------- 56 Radio System description: TUNER EU/US/RDW H42 Software number: 4E0910541Q Software version: 0620 Hardware number: 4F0035541L Serial number: 394C$077748843 Coding: 0000002 Trouble codes: No trouble codes found --------------------------------------------------------------- 61 Battery Regulation System description: J0644 BEM H12 Software number: 4F0910181E Software version: 0590 Hardware number: 4F0915181A Hardware version: 000 Serial number: 00000000039204 Subsystems: System description: von VA0 2703121835 Software number: 4F0915105D Long coding: 344630393135313035442056413032373033313231383335 Trouble codes: No trouble codes found --------------------------------------------------------------- 62 Rear Left Door System description: TSG HL H21 Software number: 4F0910795E Software version: 0050 Hardware number: 4F0959795E Coding: 0051754 Trouble codes: 02123 - Door warning light / entry light Electrical error in circuit static --------------------------------------------------------------- 65 Tire Pressure System description: Reifendruck 3 H05 Software number: 4F0910273B Software version: 0100 Hardware number: 4F0907273A Serial number: 00000900044192 Coding: 0062725 Trouble codes: 02214 - Tire pressure warning static --------------------------------------------------------------- 67 Voice Control System description: SDS 3501 US H45 Software number: 4E0910754Q Software version: 0630 Hardware number: 4E0035753A Serial number: 00000702270442 Trouble codes: No trouble codes found --------------------------------------------------------------- 6C Rear View Camera System description: J772__Rearview Software number: 4F0910441 Software version: 0050 Hardware number: 4L0907441A Serial number: 525PA8-J7X20GJ Coding: 1000204 Trouble codes: 00778 - Steering angle sensor Please read DTC static --------------------------------------------------------------- 72 Rear Right Door System description: TSG HR H21 Software number: 4F0910795E Software version: 0050 Hardware number: 4F0959794E Coding: 0051754 Trouble codes: No trouble codes found --------------------------------------------------------------- 76 Parking Assistance System description: Parkhilfe 4-Kan H09 Software number: 4F0910283F Software version: 0060 Hardware number: 4F0919283F Serial number: 06230706215399 Coding: 0021306 Trouble codes: 01545 - Left rear park assist sensors Open circuit/short circuit to ground static 01548 - Right rear park assist sensors Open circuit/short circuit to ground static 01546 - Center left rear park assist sensors Open circuit/short circuit to ground static 01547 - Center right rear park assist sensors No signal/communication static --------------------------------------------------------------- 77 Telephone System description: Handyvorb2 H11 Software number: 4F0910336H Software version: 1130 Hardware number: 4E0862335 Serial number: 00000007535777 Coding: 0010900 Trouble codes: No trouble codes found This is the biggest mess I’ve ever encountered. I don’t know if I’m being to emotional but I’m just lost. Any help would not only appreciated but passed on whenever possible. Thank you gurus in advance. Drive safe my Audi family.I HOPE YOU ENJOY. She will be perfect. It takes time and a lot of damn money!
Seems like one disappointment to the the next.
Cut the S-line n S6 bmprs lower ends off. S-LINES lower was beautiful. So i opened the lower end up a lil. Yes it will scrap. Rip off w/ the crap drives round here. But i know a body man.
Turned out great!
Clean clean. We shell see.
WALNUTS!
Hmmm..lets give that tight hot V10 some air over her..hasnt yours ever get hot and just bogs a lil. Especially in 90 degrees on up. Well be safe . But go drive harder (track) youll see.
Find Center..the only time I took any type of measurement. For all three holes. I was so focused. I wasn't sure what would come out of it. Was bored waiting on a millionaire to help me finance this build..lol (broke for a year about)
Yup.
Gonna be difficult to blend the coutures. I dont use more that ⅛inch in filler products. I used an aluminum all metal type base then a skin of icing.
Well i wonder if it fits..YIKES!
Here we about to the heart removed from this soon to be 17 year old. Whom identifies as a n Audi . Wants Full straight x-piped works also. But the Technician must make sure the accident didnt make her a Parts land car.
We see the operation is almost ready fir the next phase. .
Leak was fixed. Sensors chsnged..read above. Im on a phone doing this..lol
BUILD!
I fabricated everything body. Nothing really out there. Thats not ridiculous in price. I mean f-ing suck ridiculous! Learn to fabricate. Or try. At least.
Almost done!
DRL'S they work. My car doesnt like em. But i got after markets..and customized em a bit. Idk why she doesnt like her new daytime lookers.
I just wanted to hear if she sounds as good also..
Lower end is opened up. Breathe you hot *** block.
RIMS CAME! 18\" SATIN BLK. LIGHTER BY 8LBS
They worked..after the drive sumtin apparently got muckered up. Ill check em later.
Pushed her out some as well . Deleted useless heavy washers. Got AL framing built for some reason. With a nice skid plate. Also im in thevworks of making her cire bumper rad all come off as one. Just remove plugs n lines. Coresupport bolts bumpers bolts (drill access holes use black plugs. I have everything already quick disconnect.
I like it..a lot.
90 DECIBEL AT IDLE...you cant stand behind and not have ear protection at rev.
Help please. My dream of 10 years labor if 5 is almost there.
jmaddog
Dec 5, 2023 04:11 PM
CartoonDog
Oct 27, 2008 09:23 AM
absolutcq20v
12
Jul 22, 2007 06:16 AM
alms_lefko
Feb 4, 2007 02:07 PM
