A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2007 A6 Avant fault codes
Old Nov 21, 2023 | 03:21 PM
Jrdntelf's Avatar
Default 2007 A6 Avant fault codes
Hi Everyone!
I bought this car about 2 weeks ago with out bringing it to an Audi/Euro shops before purchasing it, and I've been running into a bunch of issues. I replaced a connection to one of the VVT valves, bank 2 valve 2, thinking it would solve the code down below, but could not get the code to stay cleared. The wires were slightly exposed and it was frail so I assumed it would be best to just go ahead and replace it. It was showing as004180 - Bank2; Exhaust Cam Adjustment Valve 2 (N319)
P1054 - 009 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 4
Fault Frequency: 9
Reset counter: 40
Mileage: 276136 km
Time Indication: 0
Freeze Frame:
RPM: 1440 /min
The connector on VVT valve on the same side is broken as well, it is fully seated but it doesn't clip in place. I intend to replace this as well. Before I shut the hood, I followed the wiring from the other VVT valve back to the wiring harness, all the way to the ECM. Nothing stuck out so I shut the hood and checked to see if the code would clear, which it did! There was no way of telling if the problem was coming from the connector not snapping into place, of if there's possibly a short in the wiring harness. The CEL stayed off for about a week and came on today during my commute to work. Before I left work, I did the same two things for the sake of every thing working properly, and when I got home I was able to clear the code.
I suspect that there is some sort of wiring issue because when the check engine light stays off, the driver side door locks and the car chirps when I press lock on the fob. The driver side door for the past few days has only locked/unlocked about 50% of the time. Also, the ac stopped blowing cold air a few days ago and now the ECON button cannot be turned off. The AC system is showing a ton of codes.
I just did on full scan and there are so many codes, I don't even know where to start. I'm hoping some of you brilliant people might know whats going on by looking at the full system scan down below, and maybe point me in the right direction or diagnose a few things that might be making everything else code. Thank you in advance for your time!
Tuesday,21,November,2023,18:41:22:15075
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WAUKH74F97N139546 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 36 42 46 47 4F 52 53
55 56 61 62 65 67 72 77
VIN: WAUKH74F97N139546 Mileage: 277450km-172399miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Not registered 0001
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Not registered 0001
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 C HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0070
Revision: --H20--- Serial number:
Coding: 010D0109190F0120
Shop #: WSC 09414 444 100782
VCID: 2C010ED6EA08995AA3B-8078
VINID: 9D195B6071162477810C91441883C62B77
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F2 910 156 G HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H01--- Serial number: 4300681
Coding: 0000002
Shop #: WSC 02325 785 00200
VCID: 290FF7C2E5FA8C7258D-807C
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 6695BCFE3464630AB5F-8032
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 22
Mileage: 276898 km
Time Indication: 0
Date: 2006.11.23
Time: 12:02:36
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x42A2
Hex Value: 0x0024
Hex Value: 0x0193
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 A HW: 4F0 905 852 C
Component: FBSAUDIC6 ELVSG H01 0030
Revision: 31050601 Serial number: 10601200690517
Coding: 0000139
Shop #: WSC 06402 785 00200
VCID: 2411E6F682D8511A6BB-8070
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 C HW: 4E0 035 729
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 303CK077533437
Coding: 0001003
Shop #: WSC 00000 000 00000
VCID: 2313E5EA87D65622121-8076
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
Subsystem 4 - Serial number: 010535ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000000368996
Coding: 0524582
VCID: 1C61DE16BAA869DAD3B-8048
15 Faults Found:
00756 - Left Vent Temp Sensor (G150)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Temperature: 12.0°C
Voltage: 13.10 V
00757 - Right Vent Temp Sensor (G151)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Temperature: 12.0°C
Voltage: 13.10 V
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 274622 km
Time Indication: 0
Date: 2023.09.30
Time: 17:07:48
00818 - Sensor for Evaporator Outlet Temperature (G263)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Temperature: 12.0°C
Absolute Pres.: 1.2 bar
Voltage: 13.10 V
Current: 0.500 A
00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 121.0
(no units): 255.0
02784 - Left Front Upper Body Outlet Position Sensor (G387)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 40.0
(no units): 255.0
02785 - Front Right Upper Body Outlet Position Sensor (G388)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 40.0
(no units): 255.0
00731 - Potentiometer in Positioning Motor for Left-Hand Footwell Flap (G139)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 225.0
(no units): 255.0
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 220.0
(no units): 255.0
00730 - Potentiometer in Positioning Motor for Central Vent (G138)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 30.0
(no units): 255.0
02765 - Cold Air Flap Motor Position Sensor; Front (G315)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 35.0
(no units): 255.0
00733 - Potentiometer in Positioning Motor for Rear Footwell Vent (G141)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 111.0
(no units): 255.0
02763 - Potentiometer for Indirect Ventilation Flap Motor (G330)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Voltage: 13.10 V
(no units): 30.0
(no units): 255.0
01592 - Air Quality Sensor (G238)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:18
Freeze Frame:
Temperature: 12.0°C
00256 - A/C Pressure/Temperature Sensor (G395)
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:32:31
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 M HW: 4F0 907 279 A
Component: ILM Fahrer H22 0320
Revision: 00000000 Serial number: 4F0907279
Coding: 0004103
Shop #: WSC 02156 785 00200
VCID: 333315AA3736C6A2E21-8066
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02156
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02156
2 Faults Found:
02747 - Solenoid for Bi-Xenon Shutter; Right
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 2
Fault Frequency: 2
Reset counter: 2
Mileage: 262136 km
Time Indication: 0
Date: 2023.10.31
Time: 15:18:00
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 27
Reset counter: 2
Mileage: 262136 km
Time Indication: 0
Date: 2023.09.30
Time: 17:16:00
Address 0E: Media Player 1 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H09 0700
Revision: 00000000
VCID: 270BF1FAFFEEBA024E9-8072
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 66 AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0F36KV
Coding: 0013878
VCID: 2A0D08CEE0FC876A517-807E
Subsystem 1 - Part No: 4F0 910 339 A
Component: BF-Gewichtsens. H02 0050
Subsystem 2 - Serial number: 6332CSME1723381E0
Subsystem 3 - Serial number: 6342CSME163A0D22%
Subsystem 4 - Serial number: 6352QSME26483519F
Subsystem 5 - Serial number: 6362QSME2463156DI
Subsystem 6 - Serial number: 63734SME225C3A4B7
Subsystem 7 - Serial number: 63834SME20772875/
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90055070610225
Coding: 0012042
Shop #: WSC 02323 785 00200
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 950 S
Component: KOMBIINSTR. M73 H13 0170
Revision: 00000000 Serial number: 5F5778N27
Coding: 1297207
Shop #: WSC 09361 001 104857
VCID: 2019EAE696C04D3A0F3-8074
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 130080722384C8
Coding: 6CFE53CD334104
Shop #: WSC 04167 004 104857
VCID: 270BF1FAF3EEBA024E9-8072
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 167
Mileage: 274622 km
Time Indication: 0
Date: 2023.09.30
Time: 17:01:54
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBG3191149
VCID: 1869C2064E9005FAF73-804C
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0000001
Shop #: WSC 02335 785 00200
VCID: 619FAFE2DD4A043240D-8034
1 Fault Found:
00461 - Control Module for Seat Memory; Passenger (J521)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 46
Reset counter: 2
Mileage: 12476 km
Time Indication: 0
Date: 2023.09.23
Time: 18:22:31
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 R HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000103045749
Coding: 010F57201740410001
Shop #: WSC 02391 823 56573
VCID: 46D55C7E58A4430A55F-8012
1 Fault Found:
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 277457 km
Time Indication: 0
Date: 2023.11.21
Time: 18:33:38
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01036868430000
Coding: 4639385
VCID: 2E0504DEDC14EB4A8DF-807A
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
2 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 2
Mileage: 265666 km
Time Indication: 0
Date: 2022.12.05
Time: 10:31:16
01518 - Bulb for Back-Up Lights; Left (M16)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 6
Mileage: 276011 km
Time Indication: 0
Date: 2023.11.03
Time: 16:37:29
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000804730
Coding: 0000156
2 Faults Found:
02753 - Inside Microphone (R74)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Reset counter: 1
Mileage: 274622 km
Time Indication: 0
Date: 2023.09.30
Time: 17:26:01
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 1
Mileage: 274622 km
Time Indication: 0
Date: 2023.09.30
Time: 17:26:01
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000043712
Coding: 0002014
VCID: 5EE5941EEC343BCA7DF-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0036587
Shop #: WSC 02327 785 00200
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 02324 785 00200
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000016
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 394G.057576750
Coding: 0000004
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000037513
Shop #: WSC 09211 444 59190
Subsystem 1 - Part No: 4F0 915 105 E
Component: von VA0 570228S05B
Coding: 344630393135313035452056413035373032323853303542
Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0036394
Address 65: Tire Pressure Labels: 4F0-910-273-BA.clb
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700043649
Coding: 0062221
VCID: 221DE0EE98CC5F2A197-8076
1 Fault Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 1
Fault Frequency: 28
Reset counter: 19
Mileage: 276136 km
Time Indication: 0
Date: 2023.11.05
Time: 15:17:13
Freeze Frame:
(no units): 0.0
Temperature: 26.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000507130010
Shop #: WSC 12336 024 394758
VCID: 2D0703D2D1129052B45-8078
3 Faults Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 5
Reset counter: 1
Mileage: 274620 km
Time Indication: 0
Date: 2023.09.23
Time: 19:07:52
00474 - Control Module for Immobilizer
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 24
Reset counter: 38
Mileage: 274620 km
Time Indication: 0
Date: 2023.09.23
Time: 19:13:48
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 119
Reset counter: 1
Mileage: 274620 km
Time Indication: 0
Date: 2023.09.23
Time: 18:22:25
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0036394
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005077685
Coding: 0010970
Shop #: WSC 09414 444 84478
VCID: 2809F2C6FEF0B57A473-807C
End----------(Elapsed Time: 01:52, VBatt start/end: 13.5V/13.4V)-----------
Old Nov 21, 2023 | 07:20 PM
AudiAllTheWay's Avatar
Community Builder
Check for open HVAC fuse as the DTC’s suggest many HVAC components have lost access to power.
Try clearing Steering Angle DTC and see if it returns. This is a common code after a battery disconnect but yours says intermittent with a very old date stamp so there may be more to it.
Try clearing the Airbag DTC’s and see if they return. Sometimes these codes appear due to extreme cold weather. If the DTC’s return then disconnect battery and inspect connector under seat for moisture damage, otherwise may need two airbags replaced.
Appears some modules have been replaced that have Component Protection. If you don’t have the original module(s) then will need a trip to the dealer or an ODIS shop.
Amber_Rose_Bailey
14
Feb 3, 2025 07:38 AM
Toblahoe
Oct 7, 2023 03:19 AM
Ewuschris
Oct 19, 2021 10:02 AM
RodriguesV
Jan 6, 2018 08:21 AM
AudiBoston34
12
May 10, 2016 12:53 PM
