UK: Car is in safe mode
I will try to explain this as simple as I can .
I Had problem with locking module (under steering wheel) .
My car been towed away few days later home .
So I did some soldering on the module 3x switches and 1 relay.
That didn't help.
So I bought a set from nother A6 C6 with similar codes ( key, ignition module and locking module)
I've changed all that and hooray car unlocked the steering wheel , turn the key and car started and stopped. Now its got SAFE saying at the cluster.
Any ideas? Can I do something without programming or keys needs to be programmed to imboliser? Or locking module itself?
That's how it looks now.
This is the set I bought.
02095 - Ross-Tech Wiki.
You might also contact your dealer and see if they will do a reset for you. The dealer in my area will not.
Some key lockers told me that.
( you need a locksmith to program the key to the car/sync the steering module up with ECU) is that can be true?
As for now I'm searching for people who can remove component protection and make it work . I was thinking that I don't need to code keys. As if it's would be key problem , it wouldn't start at all. Would be the same thing like with old key. Just blank dashboard. But this is just a thought 💭. Thanks for reply
Note transplanting the 8 pin eeprom does not work on much newer modules as Audi eventually moved CP content into onboard flash of large processing chips which are 80 to 160 pin QFP’s making for a more challenging transplant.
This procedure is not for everyone. If you know someone who does board level surface mount repairs then it is easily done with the right tools and experience.
