A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
View Poll Results: Would you perform this swap?
Would you performe this swap?
0%
Is this swap a good idea for the C6?
0%
Do you think there is another option?
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
PCV Relocation, now, SC belt is loose!
Old Dec 14, 2023 | 09:55 AM
In4cus's Avatar
Default PCV Relocation, now, SC belt is loose!
So, I found on YouTube, a great fix for our failing PCV that sits in the engine valley. Check out Audi C7 Owners, Cameron is the channel owner and he gives you great step by step instructions on how to do it. He also gives you the parts needed to complete the project. So, I did it along with a bunch of other things he shows you. Now, I know he is doing it on a C7, but, everything he showed fit on the CAJA motor. The LAST THING is to put the SC belt on. Since the replacement PCV is not as tall as the OEM one, I think that is causing the SC to sit lower, there by not creating the needed tension on the belt. He said ti SHOULD T have caused a change in belts size...but it did.
Has ANYONE ELSE performed this swap? Did you use rhe same size belt?
This is the 3.2 v6 pcv. It fits in like the plastic oe ine. But it has an aluminum upper, will withstand heat better.
Here is the ocv without everything on top of it.
Old Dec 14, 2023 | 03:01 PM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
The height of the SC is based on the intake, I don't see how deleting the PCV would affect this?
Old Dec 14, 2023 | 08:26 PM
In4cus's Avatar
I'm such a goof, I threw away the old belt without noting the size.
coupe302
A4 (B7 Platform) Discussion
Jul 27, 2011 10:06 AM
chris00tt
9
Aug 19, 2006 06:02 PM
egp320i
20
Jul 21, 2005 06:37 AM
dorsal900
12v V6 Discussion
12
Jan 20, 2004 06:13 PM
