A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
replacing rear lower control arms
Old Dec 19, 2023 | 07:04 PM
OutaTheBox's Avatar
Default replacing rear lower control arms
replacing rear lower control arm, the right side is so rotted it actually broke, the left side is not far behind. will be replacing both sides and "while i'm in there" shocks, rotors and pad . i have factory procedure downoladed from erWIn, but am looking for any practical guidance.
Also I have found a coil spring compressor that goes thru the center of bottom spring perch, that i **think** will do the job, ...opinions,comments?
Old Dec 20, 2023 | 08:40 PM
AudiAllTheWay's Avatar
Community Builder
Your rear spring compressor looks the schnizzle 👍
Suggest place a rag between the two clamp arms and replacement spring to protect the finish during install, and replace the deteriorated lower spring base.
Last broken spring I had on a back coilover of a B5 S4 and now on the third set of rear springs. Once the finish opens up then corrosion sets in and it is the beginning of the end for the spring. Fact of life for winter driven cars.
Old Dec 21, 2023 | 06:21 PM
OutaTheBox's Avatar
so in the end not that bad a job. most of the time was spent trying to figure out how best to use the ABN spring compressor and dealing with the typical heavily rusted fasteners, weld nuts that let go etc.
In the end i realized the spring does NOT need to be removed for this job, just compressed enough so there is no pressure on the control arm. I hooked the top of the compressor at the top end of the spring and then i pur the "horse shoe" shaped bottom piece under the control arm and comprerssed the spring down towards the bottom of the pan. you need to use plenty of grease on anything that turns.
gstroe
12
Dec 19, 2023 06:07 PM
JohnLZ7W
14
Mar 19, 2008 07:46 PM
galkokolaf
Mar 18, 2008 01:01 PM
Three-twelve
12
Dec 6, 2007 07:19 PM
S4_Me_CT
Apr 23, 2006 04:01 PM
