Help identifying coolant leak
- PCV Oil Separator
- Thermostat
- Thermostat cross over pipe and o-ring connections
- If this is a 3.0T then leaking black plastic bleeder screws on each of the supercharger intercoolers
If the engine has been overheated due to low coolant then recommend to replace all the above while the intake / blower is removed as these parts get cooked.
- PCV Oil Separator
- Thermostat
Since it's a 3.2, take a look at the vacuum pump as well, if it is leaking you can get a cheap seal kit from RKX(RXK?) off eBay/etc that reseals the entire thing, much cheaper than a new pump.
Oil leaks at the rear upper covers solution is R&R the covers plus a tube of sealant. Can replace the upper tensioners while open.
Understood if it is time to sell but simply to note these fixes are DIY friendly.
