2006 Audi A6 3.2 - No dash display in center and intermittent MMI - NO START
1) I went to start the car - ignition key turned and the steering is unlocked- and won't re-lock. No crank, and the steering lock is a new issue. The OBD scanner will power up, but can't connect to the car. Tried the hazard, lights, and brake pedal hold trick and unable to connect and clear codes. The car battery is new/ 13.5 volts
2) No dash lights in center portion of the display in front of the steering wheel - this is a common Audi problem so I replaced/soldered in a new relay and microswitches in the steering column module - tested repairs with ohm meter. No changes. I did not replace the motor - should I have?
3) I noticed the MMI is intermittently working, slow for the MMI to illuminate at times, and when MMI is on I can select radio stations but won't play.
4) MMI is always blank now - once in awhile a Audi symbol will flash for a few seconds on the screen. The only time the other dash lights are on is if the door is opened, or headlights switched on.
4) Lost power to glove box release, manually unlatched, but now works properly again. Was able to set parking brake, but not release parking brake.
4) I started eliminating modules with an optical loop bypass, and doing a 10 minute battery disconnect to reset. I only have one bypass loop and tried each individual module in the loop - no changes.
5) I checked all fuses in the engine bay, driver and passenger side fuse boxes - all test good. I swapped all the relays that I could if there were two of the same - no changes.
Random thoughts - are the MMI issues related to the steering column module or two completely separate issues? Do I need Vag-com or VCDS to clear fault codes and run optical loop test? Can I put an optical loop bypass in for each and all modules?! Do I leave each module unplugged when optical loop bypass is installed? Can I bypass each module, such as the gateway module? Is this just a bad relay or bad ground somewhere? Anywhere I should test for voltage in the fuse panel? Starter solenoid signal wire? And lastly, could this just be the MMI control panel in center console?
Any advice and input is greatly appreciated! I feel like the root problem will be simple stupid.
For the MMI, if you are in total lockout, it won't come on. If it still has issues, are you sure you checked optical bypass on every single module? The #1 and #2 causes for MMI inop on C6 are the bluetooth module, and the bose amplifier, in that order. The bluetooth module is under the drivers seat (actually slightly in front, under carpet, as long as you don't have lumberjack hands you can just pull the corner of the carpet up, weasel the plastic box out, and remove the module with the seat in) and it gets flooded when the cowl drains plug, usually happens in winter when the crap plugging the drain up gets ice in it. You can replace the bluetooth module without any coding, it is plug and play. For the bose amp, primary cause of failure on those is on the avants, the rear washer hose breaks and leaks. If you don't have an avant, the bose amp is probably fine.
What OBD scanner are you using? If it's a generic one you may not even have access to the J518 module.
Fingers crossed that I can get the car to communicate to clear the fault codes. Am I on the right path?
I am moderately capable with tools. I have seen one approach to your J518 module which is to clip the wire for the steering lock and your more ambitious program. Any thought on the difference in outcomes? I do not need to be stranded in this car but it spends a fair amount of time driving to remote areas for bicycle rides.
Thanks
Thanks
For soldering, there is a product called "chipquik", there is a generic brand which is sold on Amazon for a good price. This stuff is a solder type alloy with an extremely low melting point. If you want to make the job super easy from a soldering standpoint, you can use this stuff. You use solder wick to remove the bulk of the exposed solder (I prefer Quick Braid's Easy Braid product, any braid will do just make sure the braid has flux in it, flux-free braid is a pain in the ***). Then you put some chipquik flux on and alloy in this low temperature stuff. Once you alloy all the pins on the relay, if you're quick enough you can actually melt all the joints with the iron and they will stay melted long enough to remove it. The switches are easier than the relay. Then you just clean up the holes with the solder wick, then clean with some iso alcohol, solder on the new parts, and once again clean with some iso.
For cleaning, I use the little horse hair flux brushes you can get at hardware stores that sell plumbing supplies, I cut the brush to somewhere between 1/4 and 1/2 its original length so that it is stiffer and this allows you to brush any areas where flux has hardened. I finish with Q tips, I like the wooden shaft medical type Q tips but any will do. Always use the purest iso alcohol you can get, I think you can get 90%+ at the department store, I use the 99.9% stuff that I buy by the gallon.
As far as snipping the wire, I have never used that approach but have read about it. I think you may need to snip it while the column is unlocked. In general I am not a fan of that approach because now there is no longer a steering lock, I know from a safety risk stanpoint it's probably not a big deal unless you live in some crazy hilly place but I always try to do the "OEM style" repair.
If you are wondering what type of soldering iron, it just depends on whether you want to spend $20 on something that will get the job done, or closer to $75-100 for a lower end temperature controlled soldering station that will be useful for other soldering projects. For tip cleaning while soldering, no need to buy anything special, you can cut a little square out of a household sponge, wet it and put it in some small container like the cut-off bottom of a plastic water bottle, and as you are soldering you can just wipe the tip on that sponge to clean it up nicely.
For solder that you use to install the new parts, these boards were probably lead free even though they were made in the mid 2000's but 60/40 lead solder will work fine as well, and will be easier to work with and more reliable (though these particular solder joints don't have problems with failing whether or not you use lead free).
My oldest repair for the J518 module was around 2016-2017, a model year 2005 or 2006 C6 A6 and that car is still driving problem free today. I used the part numbers referenced in my other posts, and I did not replace the lock motor on that car. I believe it is up to around 250k miles now and the failure was around 125k miles. You can remove the security screws with a strong pair of small vice grips that have nice sharp jaws, but it is kind of a pain. Deepening the slot in the screw with a rotary tool makes the screw removal easier, however you have to put something down on the carpet to keep the metal filings out, and I wear a full face mask with a hoodie with the straps tied tight over my head and the perimeter of the mask because that job is a particularly excellent way to cover your head with metal filings. I really like my eyeballs the way they are.
