MMI sudden issue
QUOTE=A6Gary;25873622]What year is your car?[/QUOTE]
Obviously resolve the water leak first then fix the electronics.
You could try cleaning the corrosion from connector pins with Dexoit red can or similar. Could open the module and inspect electronics for water damage, etc. Used replacement modules are available but you will likely run into Component Protection DTC when you replace it. If your original module is not salvageable then recommend do not throw it away as it would be useful for a CP eeprom chip swap into a replacement module to avoid CP.
Could try posting in the C7 forum for more help.
QUOTE=AudiAllTheWay;25873890]Your chassis is considered a C7. Your module was manufactured late 2011 but I suspect the chassis is MY 2012. Also can depend where on the planet you are located as Audi had staggered release dates in different countries / continents.
Could try posting in the C7 forum for more help.[/QUOTE]
QUOTE=jonzie77;25874059]Just because it is "dry" doesn't ensure that it will work. The water intrusion almost certainly carried minerals with it and could, therefore, leave trace amounts behind resulting in semi-shorts as it were. I'm not saying that it isn't worth trying to clean it up but just applying power to it when it "looks" dry probably won't cut it. Use a >90% alcohol or even distilled water and a long, soft-bristled brush to flush any traces of deposits away. The good news is such deposits usually release pretty easily from the solder mask on circuit boards.[/QUOTE]
