A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
AE: C6 high fuel consumption and excessive smoke from exhaust
Old Jan 8, 2024 | 11:37 PM
Tariq Shanti's Avatar
Default AE: C6 high fuel consumption and excessive smoke from exhaust
hello Audi mates..
wish you all good times
i noticed in my car lose of power and increase petrol consumption so i did a diagnostic test by OBD11
i am not expert but i think it may be all related and i am asking kindly for your help and guide
Date: 2024-01-09 12:19
VIN: WAUBGC4FXBN001244
Car: Audi A6
Year: 2011
Body type: Saloon
Engine: CAJA
Mileage: 247390 KM
01 Engine
System description: 3.0l V6 TFSI
Software number: 4F1910551B
Software version: 0040
Hardware number: 4F1907551B
Long coding: 01050010190F0160
Trouble codes:
P2257 - Secondary air injektion System Control "A" Circuit low
static
Priority: 4
Frequency counter: 1
Driving cycle: 255
Mileage: 247351 km
Date: 2010-02-05 17:57:15
P0414 - Sec.Air Inj.Sys.Switching Valve A Circ. Shorted
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
P0417 - Sec.Air Inj.Sys.Switching Valve B Circ. Shorted
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
P1425 - Evaporative Emission (EVAP) Canister Purge Regulator Valve Short circuit to ground
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
Date: 2010-02-05 17:57:16
P0091 - Fuel Pressure Regulator "A" Control Circuit Low
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
P0090 - Fuel Pressure Regulator "A" Control Circuit/Open
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
P2009 - Intake Manifold Runner Bank 1 Control Circuit Low
static
Priority: 4
Driving cycle: 255
Mileage: 247351 km
P0140 - O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
static
Priority: 4
Driving cycle: 255
Mileage: 247360 km
Date: 2010-02-05 19:35:20
P0160 - O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
static
Priority: 4
Driving cycle: 255
Mileage: 247360 km
P164E - Oil pressure regulation valve Electrical error
static
Priority: 4
Driving cycle: 255
Mileage: 247387 km
Date: 2010-02-06 10:20:40
Old Jan 18, 2024 | 12:37 PM
i went to local garage.. i replaced breather hose.. new plugs.. cleaned injectors.. cleaned valve manully and replaced high pressure fuel pumb and still getting the same codes and my car start misfiring on 2000 RPM.. i start losing hope guys any help plz
Old Jan 19, 2024 | 11:31 PM
Avantly's Avatar
Banned
When the HPFP fails, it usually is not the HPFP itself, but the pressure transducer/regulator on the HPFP. When this fails, at least on the Simos 6.22 ECU from the pre-facelift cars, it often blows the output from the ECU. I've replaced many ECU's for that issue on them. If you replaced the HPFP and the code for the pressure regulator persists, you may want to investigate the ECU further. 2011 should have Simos 8.30 and I am not sure if that ECU has the same problem as Simos 6.22 or not. Cheapest route is to get a junkyard ECU with matching part number (OK to use one with newer software revision) and get someone to clone your existing ECUto the new one (or do it yourself if you have the right tools). I wouldn't replace the ECU until you have verified that it is at fault. Did you clear all of those codes, and they are still coming back after the repair?
Old Jan 20, 2024 | 06:42 PM
I Still got the same codes after clearing msgs.. i checked modules and all good ..i did cleaned the intake.. i noticed also my alternator is oily (leaks fixed allready) and my headlights flirking I don't know if that mean the alternator start to fall but i will try to replace the ECU as well
Thanks for replying
Old Jan 20, 2024 | 10:00 PM
Avantly's Avatar
Banned
Thanks for replying
Don't replace the ECU unless you are sure it is a problem.
All these codes are still present after the repair?
The car is still leaking oil after the repair?
Old Jan 21, 2024 | 12:25 PM
Leaks fixed prior to this issues.. no current leaks.. car run smooth with epc untill certain point then start behave abnormal ..
ukh
A8 / S8 (D5 Platform) Discussion
13
Apr 1, 2024 02:43 PM
LandofQuattro
A6 (C7 Platform) Discussion
10
Mar 12, 2016 02:38 AM
drwikboz
Q7 MK 1 Discussion
Mar 7, 2016 02:34 AM
TEBELLEH1
Nov 5, 2004 05:21 PM
eswanti
21
Feb 6, 2004 01:41 PM
