A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
A6 4F 2004 Starting Issues
Old Jan 14, 2024 | 12:29 PM
Shin420's Avatar
Default A6 4F 2004 Starting Issues
Hello, so yesterday i turned on car and everything was fine drove for about 20 kilometers.... left it... for 5 minutes came back cannot start... I turn off the cable off of ELV and turned it back on there was contact and i could start it but it instantly turned off... Couldn't lock it... Had to call help.
So i bringed my car back home to work on it... I did ELV Repair Changed ACT512 relay and J518 switches... placed it back on i can hear it unlocking the wheel and yet same issue remained.. after some tries to turn it on it suddenly stop giving me any signal... Contact was not there no crank no ignition no nothing... Like its dead Only MMI Worked. Lights didn't work aswell. Changed battery nothing. did jump start nothing... Cleared off all faults nothing... I am really losing my mind up in here. I also did check most of the relays everything was fine. Fuses are all ok aswell. Idk what to do guys help me up please... I really need my car...
Here are faults. Oh ye like EVERYTHING has fault or not being reached...
File Type: pdf
Old Jan 14, 2024 | 09:10 PM
jonzie77's Avatar
First thing to do is to clear all faults and try again.
Old Jan 15, 2024 | 12:35 AM
Shin420's Avatar
I did... i did clear faults and everything... nothing... I am suspecting either ECU or Dead Relay somewhere.
Old Jan 15, 2024 | 09:13 AM
jonzie77's Avatar
Any signs of water intrusion anywhere in the car (trunk, floors, under the cowl at the bottom of the windshield)?
Old Jan 15, 2024 | 10:40 AM
Shin420's Avatar
Nope.... Everything is dry... like i drove it 20 kilometers if it was water in first point i would probably get stuck in middle of the road or wouldnt be able to turn it on in the first place.
Old Jan 18, 2024 | 01:52 PM
Shin420's Avatar
Fixed it, after all it was ELV it was due to replace. Restoration wasn't gonna do it... changing microswitches was useless.. I needed a new ELV. Now everything works fine.
Rotorheard95
14
Sep 26, 2023 01:04 PM
pliers
Aug 29, 2021 05:02 PM
RobsonAF
VAG-COM Discussion
Dec 24, 2019 06:06 PM
moelharairi
Jan 8, 2012 02:48 PM
Vincent
17
Mar 26, 2002 08:24 AM
