A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
BG: A6 3.2FSI TIMING CHAIN QUESTION
Old Jan 23, 2024 | 04:39 AM
eagle_xtz's Avatar
Default BG: A6 3.2FSI TIMING CHAIN QUESTION
Hello ,can anybody help how to check with vcds timing of engine and what value must be to be good?
Old Jan 23, 2024 | 07:53 AM
das60's Avatar
The measure I use is under Engine (Module 1) , Measuring Blocks, then change 001 to 0093 and hit "Go!"
You are adding the number in the 1st and 3rd block and the 2nd and 4th block and the totals should be less than 8.
The Bank 2 measures here were a bit off normal (-0.7 & 3.4) I looked around and noticed a small oil leak at the cam solenoids and replaced the o-rings. Shortly after, they measure returned to normal. I check these at every oil change FWIW.
Recent check
Old Jan 27, 2024 | 11:31 AM
mikeagueros@gmail.com's Avatar
Default Timing chain offset at -45 deg--help!
Hi there, I'm new to VCDS, I have an issue where 2011 Q5 with 135,000 miles, just turns but doesn't start, I've changed the camshaft positon sensor, crankshaft position sensor, Variable timing valve and magnetic adjuster and still no luck. I was hoping one of these would be defective and my issue would be solved....No luck.
I am assuming my next problem error is the the timing chain. I used VCDS and got to start the car for a few minutes. Here is the view where the Position 1 sensor bank showed a -45 degree offset, can this be true or is it a novice error? I haven't been able to start the car again. Looking for any and all help!
is this reading correct camshaft adjustment cylinder at -45
Old Jan 27, 2024 | 02:43 PM
das60's Avatar
I can't comment on the advanced measuring values you have selected. The common approach is to use Block 93 from Measuring Values.
PhotonHerder
A4 (B7 Platform) Discussion
Oct 7, 2022 10:44 AM
irelandbuyer
Nov 21, 2021 09:38 AM
ericchan81
Jul 10, 2009 02:45 PM
MikTip
16
Sep 4, 2005 12:33 PM
