A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Needle Sweep on 2006 c6 A6 S-line?
Old Jan 25, 2024 | 01:22 AM
AudiManT's Avatar
Default Needle Sweep on 2006 c6 A6 S-line?
Wondering if anyone can help me on this? I have seen a needle sweep plug-in on start up on the 2009+ a6 models wondered if there was anyway i could get it to work on my 2006 c6 s-line a6 avant and what software/hardware i might need?
Cheers
Old Jan 25, 2024 | 05:51 AM
vukasin96's Avatar
Hello,
You need VCDS and you can always try on your car. Generally it needs the facelift electronics, probably the color dash. But here is the instruction on how to
Facelift Cars - '58 plate onwards
1. Enabling Gauge Test/Needle Sweep
[Select]
[17 - Instruments]
[Coding - 07]
[Long Coding Helper]
Click on the second byte in the list.
Check the box for "Gauge Test/Needle Sweep active"
[Do It!]
Old Jan 25, 2024 | 05:56 AM
AudiManT's Avatar
Originally Posted by vukasin96
Hello,
[Select]
[17 - Instruments]
[Coding - 07]
[Do It!]
Will this work on my '56 plate?
Old Jan 25, 2024 | 06:01 AM
vukasin96's Avatar
Not sure to be honest. I tried on my '18 plate and did not have the option at all. So you can always check. How does your VIN end, with 58 right?
Old Jan 26, 2024 | 02:45 PM
das60's Avatar
I do not think the sweep works on the pre-facelift (2008.5) cars.
royclark
Jun 12, 2022 08:36 AM
Paracaidista2.7T
Nov 23, 2007 02:27 PM
mosso
16
Jun 14, 2006 03:15 PM
chihashu
Dec 1, 2004 12:01 PM
