2008 A6 4.2 - Help me figure out this coolant leak
2008 A6 4.2. Original coolant hoses, water pump, thermostat.
While warming up (seems to be until the thermostat opens up), I will get this cloud of vapor that sure seems to be coolant.
The coolant level will drop gradually over a fe weeks until I need to refill the reservoir.
I did a pressure test and it held pressure for an hour. Dropped slightly, but not significantly.
The vapor is coming from the drivers side, mid engine. I have looked through diagrams and don't see any coolant related things there.
I don't see anything from below (e.g. obvious vapor from around the thermostat).
I have a video from above and below. Before I take a bunch of stuff off to see what is in the area, I was hoping someone might have an idea of what this could be.
Could try a mirror on a stick with bright light to side view inspect valve cover seam edges.
Took the valve cover off, cleaned everything. Took out the cam sensor there and cleaned everything.
Valve cover gasket was replaced a few years ago and is still pretty pliable.
It also seems like I would be losing oil, but it reads right in the middle on the dip stick.
It is definitely not coolant, but I don't know how to change the thread title.
No difference. I even noticed it is doing the same thing on the passenger side too. I looked from underneath and it looks like some oil is pooled on the underside of the exhaust manifold. It is so tight in there, it's hard to see anything.
There is a lot more room on the passengers side so going to remove the air box and have a better look on that side tomorrow.
There is definitely an oil leak somewhere. Just seems odd to have this at about the same place on each side. Going to get some kind of mirror on a stick (I'm sure Harbor Freight has something) and use that too.
The vapor started almost instantly which tells me there is oil pooled there. I may also try removing the the belly pan again and flushing some water through the area to clean it out.
The burning looks like oil on both sides. Maybe the cam girdle gasket is the source. Are you getting oil accumulation in the spark plug wells?
Is the PCV performing OK?
I replaced all 4 of the cam solenoid o-rings a year or so ago. I did two smoke tests and all I found was a small leak on the drivers side intake cam solenoid.
I checked spark plug wells today when I removed the valve cover gasket. No oil there. Hasn't been a problem since I changed the valve cover gaskets ~4 years ago.
I am not getting any codes for misbehaving PVC. I replaced the purge vale ~2 years ago and have not had a problem since then.
I replaced the oil filter housing gasket ~ 1 year ago when I did a carbon clean and fuel injector clean. Any oil leaks from the top will run down the valley and out the front.
Hopefully the mirror(s) from Harbor Freight will let me see more on what i going on in there.
Last resort may be to remove the front end again so I can get a better look at what is happening on the exhaust manifold.
These are two pics I forgot to add the post with the 2nd video.
Video with no smoke:
Hopefully this is it and I can pass emissions and replace the valve cover gaskets once they get here.
