Fixing oil leaks - 2008 4.2 A6
Has original: oxygen sensors, power steering pump, alternator, water pump, thermostat, compressor, belt tensioner, timing chain guides.
It runs great at the moment, but I keep thinking the original stuff has an increasingly smaller lifespan remaining. I have taken the front end off and am comfortable with that. I could easily do the water pump and belt tensioner. What I wasn't sure about is if there is a front oil seal that can be replaced.
Any pointers would be greatly appreciated.
I recently had to replace the left side HPFP due to the coil burning out. That set me back $300 (Hitachi ebay purchase) and my wife questioned me if it was worth spending that kind of money on a car with so many miles.
At 161K miles I did have to replace the power steering cooling line return hoses due to a rupture on one.
I am like you which I have kept up with the maintenance myself and would hate to throw in the towel on a car that still runs/drives like new.
I am also not impressed with the newer models with the smaller turbo charged engines, they would be fine if you don't plan on keeping the car over 100K miles since the turbo can become a money pit after that.
I also don't know what I would replace my car with, the newer cars appear to be built cheaper than the older ones, which is another reason to keep driving what I have.
Could also be the Timing chain adjusters covers that could be leaking, or the cam girdle sealant or vacuum pump housing
My thinking is to take it off the road for a week or two, remove the front and replace the original parts. Primarily water pump, tensioner (the square hole is stripped), thermostat and whatever else I can get to. Also need to redo the front suspension bits. The car still drives great, but I am sure all the bits are tired.
I am also not enamored with the newer, smaller turbo engines. Also have no idea what I would replace it with. I have had Alfa Romeos and that would be the leading candidate.
