A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
2007 - S6 - All The lights came on
Old Feb 1, 2024 | 02:02 PM
bnero42's Avatar
Default 2007 - S6 - All The lights came on
Loooong story short - After fixing the oil leak - need to Audi rolled aluminum one - they stop the leak!
One day of peace and now all the lights are on.
Car will start up - after a longer than normal start cycle - run for a few seconds and dies stating the ESP -check owners manual.
I have attached the Scan log - I cleaned the MAFs and while i was at it the Throttle bodies too..
HELP please
~Ben
Old Feb 6, 2024 | 03:21 PM
C6S6V105.2's Avatar
Check your HPF pumps and injectors also fuel filter or even bad gas. might have a air\fuel ratio error that's causing the car to go into limp mode (ESP) check for lean or rich fuel air readings.
Old Feb 10, 2024 | 07:59 AM
bnero42's Avatar
Thank you for that - digging into it this afternoon - learning up on how to do all that and heading out.
Old Feb 10, 2024 | 08:33 AM
AudiAllTheWay's Avatar
Community Builder
Several engine codes report low battery voltage. Have a look at stabilizing battery voltage and clear all DTCs then see what codes return.
Old Feb 10, 2024 | 09:04 AM
bnero42's Avatar
Looks like the High Pressure fuel pump is blown - Wonder if these can be rebuilt vs bought... these ain't cheap...
Zip tie was added a few minutes ago to ensure connections.
Old Feb 10, 2024 | 10:29 AM
A6Gary's Avatar
AFAIK, you can only replace the HPFP. Try one of the on-line OEM part suppliers, e.g., www.autohausaz.com, for a replacement.
Old Feb 12, 2024 | 12:17 PM
jonzie77's Avatar
Are you declaring it "blown" by virtue of the connector needing to be tie-wrapped or is there some other indicator that you are going by?
Old Feb 14, 2024 | 02:10 PM
sswari's Avatar
If you messed with the TB, you need to go through the basic settings routine on them in VCDS
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2024 | 02:51 PM
A6 4.2 Vier's Avatar
I recently replaced one of my HPFP (drivers side) on my A6 4.2l.
On mine the solenoid coil went bad (open circuit). I sourced an OEM HPFP (Hitachi) from ebay for $300.
Old Mar 11, 2024 | 03:33 PM
bnero42's Avatar
I am declaring it blown as it was actively leaking fuel.
