08 A6 3.2L with P0087 (fuel rail/System Pressure Too Low)
I got 2008 Audi A6 with 3.2L I been having issue with code P0087 (fuel rail/System Pressure Too Low) sporadic. I 've replaced Electric fuel pump, fuel filter, low side fuel pressure sensor, high side fuel pressure sensor, High Pressure Fuel pump. car runs fine on smooth acceleration, but when pushed all the way it lags power and on VCDS when checking fuel Rail pressure (spec) vs Fuel rail pressure (actual) it doesn't match, also my Quantity control Valve Status stays inactive.
1 Fault Found:
000135 - Fuel Rail/System Pressure
P0087 - 007 - Too Low
Freeze Frame:
Fault Status: 01000010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 375479 km
Time Indication: 0
Date: 2024.02.04
Time: 12:12:47
Freeze Frame:
RPM: 2272 /min
Mass Air / Rev.: 403.3 mg/str
Temperature: 96.0°C
Part Throttle
Pressure: 59.5 bar
Speed: 84.0 km/h
Readiness: 0010 0001
as you can see on log my actual fuel pressure does not match spec that's where vehicle boggs down. any help would be great. any suggestion
Attached is the log of fuel system
