Transmission Issue, Adding fluid issue
My notes from when I did it are below, but it’s years since I used them so this is all I have to go on:
with engine off
Fill with fluid until trickle comes out then refit fill plug by hand
Connect vcds and monitor trans temp
Engine on, idle 650-950rpm
Select R and then D. Manually shift all gears and hold each for 10s
Run 2000rpm 30 seconds in N
Shift to P
Monitor trans temp until 30C is reached, can switch on AC for faster warm up
(If 35C is reached, allow to cool down)
Open fill plug and fill with more fluid until it runs out fill hole, then wait until 40C is reached
Wait until only single drops come from filler hole at 40C
close fill plug. 17mm hex key, 80Nm torque
Turn off engine
with engine off
Shift to P
Turn off engine
When replacing the pan gasket, don't forget about the O-Ring on the electrical connector going into the side of the tranny.
Also, since you are in there to replace the filter, might as well replace the square sealing tube that goes into the valvebody. Just drop the valvebody, I think it's officially called a "Mechatronic Unit" or something.
This one.
Pretty cheap fix overall, cost of the filter, fluid and a couple o rings.
