A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Lots of electrical codes...whatever could it mean.
Old Feb 6, 2024 | 08:53 AM
DudeDah's Avatar
Default Lots of electrical codes...whatever could it mean.
SO I am trying to get to the bottom of a "BRAKE PADS" error on my dash. Front pads have plenty of meat on them and reservoir is full of fluid, but when I ran a diagnostic, it is coming back with MULTIPLE varied electrical faults and I am wondering if anyone might have an idea what is going on. Bad battery? Here are the codes...with the usual misfires...
Basic OBD2:
P0303 (Confirmed) - Cylinder 3 Misfire Detected
Engine:
P0300 - Random/Multiple Cylinder: Misfire Detected
P0301 - Cyl.1: Misfire Detected
P0303 - Cyl.3: Misfire Detected
P0456 - EVAP Emission Contr. Sys. (very small Leak): Leak Detected
P2070 - Intake Manifold Tuning (IMT) Valve Stuck Open
Transmission:
P1890 - Signal wire for Tiptronic: electrical error
ABS:
00473 - Electronic Parking Brake Control Module -J540-: Please read DTC
Parking brake:
02443 - Operating unit: Electrical error in circuit
Infotainment display:
01964 - Memory Seat Control Module / steering column adjustment: No signal/communication
Digital radio:
02635 - Tuner not enabled/activated
00446 - Function limitation due to insufficient voltage: Lower limit not reached
Heater & air conditioning:
01087 - Basic setting not performed: no or incorrect basic setting/adaptation
Body/convenience system:
01134 - Alarm horn: Electrical error in circuit
Driver's door:
02115 - Lock unit for central locking: Implausible signal
Front passenger's door:
02116 - Mirror adjustment motor: Short circuit to ground
Trunk:
00317 - Rear lid control module: Implausible signal
Battery regulator:
02272 - Static current stage 1
02273 - Static current stage 2
02274 - Static current stage 3
02276 - Static current stage 5
02277 - Static current stage 6
Old Feb 6, 2024 | 09:06 AM
A6Gary's Avatar
Clear the DTCs and see if they come back. Also, how old is your battery?
Old Feb 6, 2024 | 11:13 AM
DudeDah's Avatar
I'll be honest...I don't recall ever having changed the battery.
Old Feb 6, 2024 | 11:40 AM
DudeDah's Avatar
Clear the DTCs and see if they come back...
ok, cleared the codes and here are the ones that came back immediately. Brake Pads light is still on though. Also ECU was reading voltage at 13.7
01087 - Basic setting not performed: no or incorrect basic setting/adaptationBody/convenience system:
Driver's door:
jxg
A4 (B8 Platform) Discussion
13
Oct 21, 2023 03:07 PM
Mario Barros
Aug 21, 2020 05:42 PM
waninae39
Q5/SQ5 MKI (8R) Discussion
Jan 18, 2017 06:02 PM
nsusammyeb
16
Jan 15, 2015 12:15 PM
cincinnati_kid
Apr 1, 2014 09:41 AM
