A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Squealing when turning at low speed
Old Feb 7, 2024 | 01:38 PM
Audiandy1970's Avatar
Default Squealing when turning at low speed
I have a 2007 audi a6 c6 2.7tdi.
Recently when turning at low speeds there is a loud squeal coming from the front of the car.
when looking at the auxiliary belt moving it slips on the power steering pulley meaning that the power steering pulley stops spinning. Im thinking its the belt or the tensioner that's causing the issue.
hoping somebody had some insight or may know what is causing it before i go and replace parts.
Old Feb 9, 2024 | 04:04 PM
AudiAllTheWay's Avatar
Community Builder
Could try unloading the tensioner and spin power steering pulley by hand. It should rotate smoothly, not have any shaft side play and not be hard to turn.
If you have the belt off then spin all the pulleys by hand and check everything for shaft play and loud bearings. Maybe it is time for a full belt / tensioner / roller service.
Old Feb 10, 2024 | 12:33 AM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
Or as simple as a dirty belt. Any oil leaks? Something dripping on the belt? You can try cleaning it with some belt cleaner, see if it helps.
Ag-Audi
28
Jan 14, 2019 11:22 AM
TheSilverBullet
Aug 19, 2010 09:13 AM
nobodeuno
13
Aug 4, 2010 07:14 PM
jibmaster1
Audi allroad
10
Dec 8, 2009 08:32 AM
MSP_S4
Jun 11, 2008 06:15 AM
