A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Got a killer deal on a 07 A6 4.2, or did I? key stuck, no start, "SAFE" message
Old Feb 8, 2024 | 03:33 PM
ryruegas's Avatar
Default Got a killer deal on a 07 A6 4.2, or did I? key stuck, no start, "SAFE" message
Hello all,
This is my first thread. I purchased a 2007 A6 4.2 that is not running. It has 155,000 miles. It is in great shape inside and out. Cost me $1000 usd
I have done a ton of digging and have not found any solutions that work yet or enough information to find a solution.
Here is what I am currently facing, along with what I have tried so far:
1. The key is stuck in the ignition. I can turn the key just fine, but it will not release. The battery was dead when I picked up the car. I had to trailer it home. Charged the battery all night inside my house at 2 amps. holds a charge just fine.
  • There is no pin hole near the keyhole to release key
  • I have tried shifting into all positions and back to the park with no luck.
  • I have the center console area removed because i was going to see if the cable was possibly misaligned but did not want to keep removing parts to get to cable yet.
  • depressing the shift release that sits under ash tray did not help
  • battery inside if key is good.
2. car will not start, when I turn key no crank
  • dash turns on
  • "safe" is displayed in odo screen
  • esp message
  • brake not working error message
  • MMI does not power on but all other electronics seem to be working.
Im not sure if the key getting stuck and the "SAFE" message are related or which issue I need to resolve first.
I was planning on figuring out how to get key free first and then move on to the no start issue.
any advice would be great.
Old Feb 9, 2024 | 07:27 AM
A6Gary's Avatar
You should scan the car to find out what DTCs are tripped to diagnose.
Old Feb 9, 2024 | 10:58 AM
ryruegas's Avatar
Just ordered the scanner from Ross-Tech. Should be here in next 2 days.
Old Feb 9, 2024 | 02:34 PM
AudiAllTheWay's Avatar
Community Builder
Originally Posted by ryruegas
Hello all,
They might be related and see if this helps:
https://www.audiworld.com/forums/a6-...e-fix-3015595/
Old Feb 9, 2024 | 02:45 PM
ryruegas's Avatar
Thanks, I'll take a look.
Old Feb 16, 2024 | 05:52 AM
sswari's Avatar
When you get your VCDS, The first thing to do is a full auto Scan with the freeze frame option turned on!!!, This will give you information on when the code was set. I had some from back in 08 on my car when I bought it 2 years ago. This will alsosave a log file that you can go back and refer to. Once that is done, you need to go in and manually clear the codes that it comes up with. Since the battery was dead, you will have a ton of them. Using the Clear DTS button will clear some, but not all of the codes, again, do it manually. Now that you have all the codes cleared, turn the car off, let it sit for a few minutes then scan it again. You will now have a good idea of what is really going on. Post your second scan for us to look at.
Old Feb 16, 2024 | 06:37 AM
ryruegas's Avatar
Thank you for the detailed reply. Tracking number shows it will arrive today. I will definitely post the results this weekend.
Old Feb 16, 2024 | 07:07 AM
G-Can's Avatar
its your steering column. Reset the codes and it will release the key.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 21, 2024 | 09:01 AM
sswari's Avatar
Got an update for us?
Old Feb 21, 2024 | 11:15 AM
G-Can's Avatar
not sure why we even bother, new member, parachutes to forum and leaves.
