A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
MMI 2G Not Working (A6 C6)
Old Feb 9, 2024 | 09:34 PM
WavyA6's Avatar
Default MMI 2G Not Working (A6 C6)
I've been stuck on fixing this radio for the past 4-5 months, and still no luck. So far my issue is the Screen not working at all (No Splash Screen Pop-Up), and none of the MMI Controller buttons light up (Besides the E-Brake obviously.) I've looped out each individual component in the rear of the car (even the Bluetooth module under the driver seat), and nothing seems to enable the screen to pop up. I don't have access to VCDS, and I'm not sure if spending 200$ is worth this old radio. All the components seem to be getting the red optical light, so my theory is either the Screen or the J523 aren't receiving power, or are just dead modules. Here's a scan from my OBDEleven scanner from a few months back. No signs of any communication to any of the radio components. (For context this scan was taken when there was a fuse in the passenger side fuse box labeled "communication" draining the battery, which gives life to the optical cables in the back of the car) (Also Fixed the "tyre pressure monitoring" there was a missing fuse")
Any help would be greatly appreciated.
OBDeleven vehicle history log
Date: 2023-10-27 14:27:15
Car: Audi
Year: 2006
Body type: UNKNOWN
Engine: kW ( hp) l
Mileage: UNKNOWN
Full scan
Control Units: 20
Fault count: 26
Control Units:
72 Rear Right Door
System description: TSG HR H21
Software number: 4F0910795E
Software version: 0050
Hardware number: 4F0959794E
Faults:
No trouble codes found
78 Sliding Door Right
Faults:
52 Passenger Door
System description: TSG BF H12
Software number: 4F0910793E
Software version: 0120
Hardware number: 4F0959792E
Faults:
62 Rear Left Door
System description: TSG HL H21
Hardware number: 4F0959795E
Faults:
55 Headlight Regulation
System description: AFS 1 H01
Software number: 4F0910357E
Software version: 0010
Hardware number: 4F0907357E
Faults:
17 Dashboard
System description: KOMBIINSTR. M73 H17
Software number: 4F0910930A
Software version: 0660
Hardware number: 4F0920980N
Hardware version: H17ÿ
08 Air Conditioning
System description: KLIMABETAETIGUNGH12
Software number: 4F0910043
Software version: 0170
Hardware number: 4F1820043S
Faults:
19 Gateway
System description: Gateway H11
Software number: 4F0910468A
Software version: 0070
Hardware number: 4F0907468D
Faults:
00384 - Optical data bus
static
01325 - Tire Pressure Monitoring Control Module
static
91 Engine
System description: ESP 8.0 quattro H05
Software number: 4F0910517L
Software version: 0090
Hardware number: 4F0614517L
Hardware version:
Faults:
01826 - Steering angle sensor, voltage supply terminal 30
Intermittent
00493 - ESP-Sensor unit
Intermittent
4F Central Electrics 2
System description: ILM Beifahrer H10
Software number: 4F0910280
Software version: 0080
Hardware number: 4F0907280B
Hardware version: ---
Faults:
00446 - Function limitation due to insufficient voltage
Intermittent
15 Airbag
System description: 66 AIRBAG AUDI8RH29
Software number: 4F0910655F
Software version: 0300
Hardware number: 4F0959655A
Faults:
02095 - Component protection active
Intermittent
00532 - Supply voltage
Intermittent
03 Brakes
Hardware version:
Faults:
Intermittent
Intermittent
16 Steering Column
System description: J0527
Software number: 4F0910549A
Software version: 0410
Hardware number: 4F0953549C
Faults:
Intermittent
Intermittent
01 Engine
System description: 3.2l V6 FSI
Software number: 4F1910559E
Hardware number: 4F1907559A
Faults:
P160200 - Power supply terminal 30
Voltage too low
Intermittent
P165300 - Read DTC memory of
ABS CM
Intermittent
P253300 - Ignition Switch Run/ Start Position Curciut
Intermittent
P307300 - Fuel pump
Electrical error in circuit
Intermittent
02 Transmission
System description: AG6 09L 3.2 FSI USA
Software number: 4F2910156D
Software version: 0020
Hardware number: 09L927156A
Faults:
P090500 - Gate Select Position Circuit
Range/Performance
static
05 Keyless System
System description: FBSAUDIC6 ELV H31
Software number: 4F0910852
Software version: 0210
Hardware number: 4F0905852B
Hardware version: 242ÿ
Faults:
Intermittent
00955 - Key 1
static
09 Central Electrics
System description: ILM Fahrer H15
Software number: 4F0910279D
Software version: 0190
Hardware number: 4F0907279
Faults:
00156 - Activation for windshield washer pump
static
61 Battery Regulation
System description: J0644 BEM H12
Software number: 4F0910181E
Software version: 0590
Hardware number: 4F0915181A
Hardware version: 000
Faults:
02272 - Static current stage 1
Intermittent
02274 - Static current stage 3
Intermittent
02277 - Static current stage 6
Intermittent
02256 - Static current
Intermittent
Intermittent
53 Parking Brake
System description: EPB CA3C0040 H03
Software number: 4F0910801A
Software version: 0040
Hardware number: 4F0907801
Faults:
01487 - System function test
Intermittent
Intermittent
Old Feb 10, 2024 | 12:29 AM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
My old 05 A6 had a similar issue, turned out to be the board under the buttons in the center console. Bought a used board off eBay, swapped them out, then everything came back to life.
My old board had white corrosion on some of the components (spilled liquids over the years)
Old Feb 10, 2024 | 10:46 AM
WavyA6's Avatar
That was actually the first thing that I had replaced, it didn't solve my problem but I don't know if I had the proper fuse in the communication slot that allows the optical wires to show the red light to the rear components. From all the videos and threads that I've read, most of them have the splash screen pop up, but I still haven't gotten to that point.
Old Feb 12, 2024 | 12:21 PM
jonzie77's Avatar
You mentioned you had an optical connection at all components, did you check for power at all components?
Old Feb 12, 2024 | 12:49 PM
WavyA6's Avatar
I know the CD Changer and Navigation Unit both have power because I can obviously remove cd's from both of them, but I don't have a single clue on how I would check power to any of the other components. I just went back into the trunk of the car, and when I "activated" the optical bus light I heard a slight popping/clicking noise which I believe is coming from the Amp. Not sure if that information will help with this case.
Old Feb 13, 2024 | 04:25 PM
Sallad's Avatar
Community Builder
Not sure if this would work, but can you start at a component, and look for the red optical light, then look for it leaving the component. Then go to the next one, look for the light going in and out of each one?? Just a thought.
Old Feb 13, 2024 | 04:34 PM
WavyA6's Avatar
Well if thats the case, then all the rear components are working, but I'm unsure if that actually means everything is working.
Old Feb 15, 2024 | 06:43 PM
WavyA6's Avatar
Anyone know what components, fuses, or wires that would stop the initial splash screen that still pops up when the Optical Bus is open?
 Pouria Savadkouei
 Michael S. Palmer
Ant Pacc
Apr 19, 2023 04:36 PM
Brian Coyle
Q7 MK 1 Discussion
10
Jun 11, 2018 06:18 AM
Brian Coyle
Q7 MKII Discussion
Jun 10, 2018 04:52 PM
mjhoward
Q7 MK 1 Discussion
Apr 20, 2018 07:24 PM
