2011 Audi aftermarket tail light (6 pin vs 7 pin connector)
Does anyone know if these aftermarket lights will work for my car?
Update 3/16/2024: See later post. The 6 pin light works with no dashboard warning lights and lack of side marker is not noticeable unless you are looking for it.
I recently bought a brand new set on Aliexpress for my 2.4 V6 and they are just the tail lights without the electrical bulb housing at the rear. If you purchase these, all you have to do is clip your electrical bulb housing into the new tail light and you're done. If you have the LED brake lights on yours which I can't tell from the picture you attached, then the AliExpress one's won't fit your car. But that white thing at the back of your tail light is the bulb holder - just unclip that and clip it onto the new tail lights. Here's a link where I got mine https://www.aliexpress.com/item/1005...1cde1802uRQfGK
Just know that you will have to transfer the gutters on the inside of the tail light to your new ones and when you do this, they will most likely break. So try and get a new set of those left and right as well. They aren't available on AliExpress and I just ordered a set from the dealer. They were around $40 each, so not cheap, but when I get them, I will fit them and publish my video. The part numbers for these are: 4F5853267C 01C (left) and 4F5853268C 01C (right).
Here's a link to the tail lights I purchased:
I'd have to take it apart again to get a pic of the internals, but under that white backing is 2 bulbs (one larger red one which i believe is the halogen brake light and a small clear one. Then there are wires which run from that white backing into the light housing with one set of wires connecting to a circuit board within the light housing.
This is how the 4F5945095K looks from the outside
AliExpress sell them for cheap - however, they are not US spec, so no sidemarker LEDs - not sure if that would give you a bulb out warning or not:
https://www.aliexpress.com/item/1005...Cquery_from%3A
I would like to order the light in the link from Amazon but it will cost too much to ship back if they don't work. In which case do know I if can swap the white housing?
I took the old unit apart, and it looks like it could potentially be switched out. But now that I know the six pin and 7 pin are interchangeable, I would likely go with AliExpress in the future because it's cheaper. Initially I bought from eBay to make the return process easier if the six-pin wasn't compatible
