A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
How do I remove / install this rubber window seal?
Old Feb 13, 2024 | 06:44 AM
Bmr0127's Avatar
Default How do I remove / install this rubber window seal?
If you look closely, you can see that a section of the outer rubber window seal tore off. I believe that the part number is 4F0837477A.
I'd like to replace this part, but I'm not sure how to remove or install it. I'm guessing it will involve removing the inner door trim/panel, but I haven't been able to find any instructions for removal or installation of this part.
Any help is much appreciated!
Old Feb 13, 2024 | 04:22 PM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
If I remember correctly, you have to remove the door glass, and you can access that piece, from the inside where the glass used to be. I replaced the window regulator on the front door many years ago, and pretty sure this is how it comes off.
The door glass will come off in a large assembly, many vids on the tube about this.
Old Feb 13, 2024 | 06:54 PM
Bmr0127's Avatar
That's what I figured, will look up how to get the window glass removed. Thank you!
Old Feb 14, 2024 | 01:55 PM
sswari's Avatar
It's not as bad as it sounds, but you do have to take the upper frame off as well. Just take your time.
Hasanj
Q7 MK 1 Discussion
Apr 21, 2025 10:54 AM
Neo1130
Jul 20, 2007 03:44 AM
saylowe
Mar 14, 2003 08:48 AM
stevestt
Apr 27, 2001 04:47 PM
