A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Alarm Horn Fault
Old Feb 17, 2024 | 01:20 AM
24V6BDW's Avatar
Default Alarm Horn Fault
I have alarm horn fault which is not possible to delete.
Alarm locking sound was coded OFF so I took VCDS and coded back to ON again, just to see would it work and there is a locking sound confirmation present, after all. There is no unlocking sound tho (don't know is this ok or not).
Any idea what's wrong here?
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Control Module Part Number: 4F0 910 289 J HW: 4F0 907 289 J
Component and/or Version: Komfortgeraet H26 0210
Software Coding: 0139505
Work Shop Code: WSC 02335 758 00200
Additional Info: 1K0951605C LIN BACKUP HORN H03 1301 4F0910177 Innenraumueberw.H01 0020
VCID: 3169A0C3A829531B74-8064
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 87
Reset counter: 109
Mileage: 296793 km
Time Indication: 0
Date: 2024.01.22
Time: 09:23:57
Old Feb 17, 2024 | 08:28 AM
sswari's Avatar
Here's the test.
1) roll down the windows
2) Lock the car with the remote
3) Set the keys down fairly close, but not too close
4) Reach inside the car and open the door
If the alarm sounds, it works, if not, you need a new horn
My A6 4.2 and S6, both had the horn in the Plenum towards the center, it is a bit down in there. Not super fun to get to, but also not horrible.
Old Feb 17, 2024 | 01:09 PM
AudiAllTheWay's Avatar
Community Builder
Replacing the alarm horn module resolved the DTC every time I have seen this code.
As sswari says the module may produce this DTC and still work but module failure is pending if the DTC cannot be cleared.
Cut the old module open if you want to see the aged out internal battery. You could try replacing the internal battery if corrosion has not yet destroyed the board.
Old Feb 19, 2024 | 04:39 AM
24V6BDW's Avatar
What do you think would it be possible to fit alarm module from A7 2016 which has HW: H05 (mine is HW: H03)?
If not, I’m thinking to take out it’s battery and replace it with mine (if board is not fried).
Old Feb 20, 2024 | 10:07 AM
sswari's Avatar
I mean you can try it, research the part numbers, sometimes the newer ones are just updated versions and will show that they supersede others.
Old Feb 22, 2024 | 05:59 AM
das60's Avatar
I am ok having this fault on my Avant........
Old Feb 22, 2024 | 06:26 AM
Community Builder
Worst case the internal failing battery corrosion can eventually cause the alarm to randomly trigger. Typically when this happens the alarm horn has likely stopped working but the park lights start randomly flashing when parked. If this happens then disconnect the alarm horn electrical connector to avoid the annoyance and save the main battery. If not replacing the module soon then bag and tie shut to waterproof the electrical connector to prevent pins oxidation for future use.
Old Feb 22, 2024 | 07:43 AM
das60's Avatar
AudiAllTheWay,
Thanks! I had not thought through the issue and simply ignored it. I will do something about it next time I am under the hood.....which is soon as I have a passenger HID issue that has me baffled. I have a good bulb in the ignitor, if I connect it all up outside the housing the light works. When I go to put it in the housing correctly it dos not.
The metal in the housing appears electrically isolated from the car. Grrr.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 24, 2024 | 02:21 AM
24V6BDW's Avatar
Problem solved by replacing it with used FL Y2010 horn. There was no water intrusion, so it was a battery issue, tho there is no dual disarm chirp, again (only locking).
Old Feb 24, 2024 | 03:27 AM
sswari's Avatar
Good Deal, so many parts are interchangable between the 4 6 amd 8, cars, glad you got it figured out.
