AU: 2007 Audi A6 2.0T fuel injectors
06F906036 is the part number which seems to come up a few times but I have seen variations in the last letter and I'm not if it makes a difference if it's 06F906036A/F/P etc.
Would greatly appreciate it if someone could shed some light on this for me, or better still direct me to a link where I can buy a set. I'm not too fussed about it being OEM or aftermarket or china copy as it's for an old s**tbox that I just need to get running. Thanks in advance!
Take a look at this.
https://www.audiworld.com/forums/a6-...motor-3057126/
Read through your post and seems very similar to what I'm experiencing. System too lean off idle and misfire in only cylinder 2 codes. Rough idle and poor fuel economy. What makes me pretty sure it's an injector issue is 1)I have swapped plugs and coils around and still same cyl 2 misfire 2) the car is extremely sluggish below 2.5k rpm ,but above it runs perfectly and seems to be making full power. 3) the problems disappear when I add Liquid Moly fuel injector cleaners to a tank of fuel, but if I add a fresh tank after, the problems come back. Tells me that the injector cleaners is making the fuel mixture richer and compensating for the bad flow, that's why I don't get that errors.
I'm hoping to get some cheap china injectors so that the car can run while I think of what to do(either sell/scrap/repair) coz there are some other things failing as well(coolant leak somewhere, alternator belts squeaking etc)
https://injector-rehab.com/
