S6 won’t idle, no power, sputtering 5.2L
the car barley idles or if u hit the gas it wants to die/ sputter very bad
i’m having a
Fuel Pressure Regulator 2 Control Circuit
code and maf codes
the car will clear up for a second if i clear the codes then falls back on its face
any tips guys my first v10 audi
Not sure if ODBII can monitor what is going on, but with VCDS, you can watch several parameters in real time air flow, miss fires, fuel pressure...
I would start with the easy stuff, air filters, MAF sensors.
You can check by removing the connector and measure ohms across the the coil on the HPFP(s).
If it shows an open circuit then the it's bad. You can also check if you are getting voltage by measuring the voltage on the connector itself.
