A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
UK: diesel Audi problems
Old Feb 23, 2024 | 08:39 AM
Migz89@email.com's Avatar
Default UK: diesel Audi problems
Hi there, was just wondering if anyone can help me with my audi a6 c6 2.7tdi le mans. My car will start in a morning but if I turn it off it won't start again. Ive put a new battery and also had it in the garage and had 2 new injectors done. I've also had a full service done incase it might have been a dirty filter.when it starts it idles and runs fine and still got power. Also if I'm driving a long distance the esp light and glow plug lights come on. Can anybody tell me what it could be as I'm having no look with garages 🙄. I've had my old reader on it and it says there's alot of underpowered components. It doesn't stall or anything like that.
Old Feb 23, 2024 | 10:12 AM
jonzie77's Avatar
The word "underpowered" sounds like a solid clue to me. I would look at connection points for corrosion/bad connections especially those requiring a lot of current like glow plugs but not limited to them. Also, by "won't start again" do you mean it does not turn over or it just won't fire up?
Old Feb 23, 2024 | 11:05 AM
Sorry the underpowered means not enough current from the battery is getting to everything. Ive checked all the glow plugs and unplugged and plugged everything in 1 by 1. Also i changed the glow plugs about 2 months ago but i couldnt get number 3 glow plug out even had it to a garage and they couldn't get it out either . Could 1 glow plug cause all this? It will turn over but wont fire. I've just changed the battery control monitor to see if it was that but nope.
Old Mar 3, 2024 | 10:19 AM
Sallad's Avatar
Veteran: Canadian Forces
Community Builder
Try a meter on your car when it's running, do you get around 14.5 Volts?
To add to the above comment, what happens when you try to restart it? Just clicks, or only cranks or nothing??
Old Mar 3, 2024 | 10:26 AM
These are some of the codes off my pals obd reader. The car just cranks but if i leave it for a couple hours it will start again. But it will start straight away if i put a jump pack on the pins under the bonnet everytime.
Old Mar 3, 2024 | 10:32 AM
I've changed the battery control module and that seems to have solved the esp light coming on as its not come on since I fitted it a few days ago. Where abouts am I checking for voltage on the battery or under the bonnet?
Old Mar 3, 2024 | 10:37 AM
Sallad's Avatar
Community Builder
Easiest spot would be the boosting points
Old Mar 3, 2024 | 10:39 AM
Ok thanks ill try that tomorrow
 Pouria Savadkouei
 Michael S. Palmer
snowchaser
A4 (B8 Platform) Discussion
9
May 8, 2009 04:49 PM
the Quiet sTTorm...
Jun 22, 2003 04:26 PM
Bromleys Tuning
Performance and Tuning
Sep 12, 2001 11:19 AM
