A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Weird electrical problems
Old Feb 24, 2024 | 12:30 PM
Quattroshk's Avatar
Default Weird electrical problems
I've had an issue since I changed my battery to a varta audi spec.
The indicators and wipers don't work I done a battery scan and it's showing as ok. I tried to code the battery with my carista dongle and its unable to connect to the central module. I've cleaned and drained the water from the plenum chamber I have water in my footwell driver side but since I drained the water it doesn't look like water is getting in car anymore. I looked at the electronic boxes under wiper cowling both of them they are dry. I checked some fuses and they all seem OK. I'm a bit stumped as to what to check next.
It says headlight range defective and my right side xenon won't power up I even changed the bulb so it should work as it powers up sometimes for a second or two then goes out
Also tonight my rear indicators have been flashing even though normal operation doesnt work. I took out a couple of fuses from trunk area to get them off and now i cannot open the boot again as its electronic.
Help me guys I'm tearing my hair out!!
Old Feb 24, 2024 | 04:29 PM
sswari's Avatar
where did all the water come from? What is the history of the car? Hell, what are the details on the car?
Old Feb 24, 2024 | 10:59 PM
Quattroshk's Avatar
The water came from flooding in the plenum chamber im sure I drained the water from the firewall area which is a common fault I havent had the car long, but I've just changed the battery and things started from tbere
Old Feb 25, 2024 | 01:56 AM
JohnnyJ's Avatar
Why did you change the battery in the first place? Did you measure the voltage with the motor running?
Old Feb 25, 2024 | 02:37 AM
Quattroshk's Avatar
A few days ago 13.8 13.9 and 14.0 readings with the engine running
Old Feb 25, 2024 | 02:48 AM
JohnnyJ's Avatar
Old Feb 25, 2024 | 05:38 AM
AudiAllTheWay's Avatar
Community Builder
The trunk should have an emergency release handle on the inside. Fold the rear seats down and crawl in or use a broom handle to reach in and open the trunk.
Old Feb 25, 2024 | 05:48 AM
Quattroshk's Avatar
I changed the battery because I thought the spec is 110 ah not 100 ah
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 25, 2024 | 06:11 AM
A6 4.2 Vier's Avatar
Do you still have the old battery? I suggest putting in the old battery to rule out a battery or battery coding problem.
My other thought is that there may be potentional circuit board corrosion issues due to the water problems that you recently had.
Old Feb 25, 2024 | 06:43 AM
JohnnyJ's Avatar
110 AH vs 100 AH can not cause any problems in normal situations. Ridiculously small capacity difference. Put the old battery back.
