Left rear door won't open from either outside nor inside, where to cut?
Anyone who have tried this before, who knows the best places to cut the inside door trim?
What about when you press the main door lock button? Can you hear anything inside the rear door?
Also can't operate window from the faculty door, but driver door can operate faulty door window just fine.
So it's a child lock thing.
This is what I can see of the wires:
One more thought, are there any special tests for the door module that allow blindly cycling the motors? If the fault is actually caused by a micro switch, maybe there is a way to tell the motors to cycle anyway even though the micro switch is saying not to? I sort of doubt such a test exists in VCDS but might be worth checking.
Here is an interesting thread on a C6 door latch failure:
https://www.audiworld.com/forums/a6-...cking-2879050/
