2011 Audi A6 3.2 dreaded TPMS, parking brake and traction control errors
00283 ABS Wheel Speed Sensor; Front Left 008 - Implausible Signal
01316 ABS Control Module - 013 Check DTC Memory - MIL On
From what I can see the car cannot see the wheel moving on the front left, I swapped the sensor from the front left to the rear left and tested it and it still does not see the wheel turn. When I removed the sensor from the front left wheel there was a noticeable amount of debris/dust/sand on the sensor, I imagine this should be a sealed space that should not have this. Any thoughts on what is going on? I'm looking for this car's workshop manuals/Bentley book. Thank you so much for your attention and participation.
Part No SW: 4F7 910 559 HW: 4F7 907 559
Component: 3.2l V6 FSI 0020
Revision: --H07--- Serial number:
Coding: 0105000A02070120
Shop #: WSC 02325 785 00200
VCID: 6ED37BBF79970CE329-803A
VINID: 9D19556D159205278018800808010A1AE9
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 40
Mileage: 119520 km
Time Indication: 0
Date: 2022.08.12
Time: 09:21:31
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 103.6 mg/str
Temperature: 94.5 C
Bin. Bits: 00000010
Load: 12.9 %
Speed: 0.0 km/h
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AK HW: 4F0 614 517 BF
Component: ESP8 front H03 0060
Revision: 00000000 Serial number: 00000000000000
Coding: 0020826
VCID: 6DD17CB37491F7FB10-8038
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 119672 km
Time Indication: 0
Date: 2022.08.16
Time: 14:08:01
Freeze Frame:
Hex Value: 0x1100
Hex Value: 0x4012
Hex Value: 0x0006
Hex Value: 0x37AC
Hex Value: 0x00FF
Address 4C: Tire Pressure II Labels: 4F0-910-274.clb
Part No SW: 4F0 910 274 B HW: 4F0 907 274
Component: J793 RKA+ H03 0110
Revision: 00000276 Serial number: 00002761104237
Coding: 0000581
Shop #: WSC 02323 785 00200
VCID: 23455A8BE2D5F18BF6-8076
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 35
Mileage: 143053 km
Time Indication: 0
Date: 2024.03.07
Time: 18:59:50
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0003
Voltage: 11.80 V
Temperature: 19.0 C
(no units): 255.0
Impact hammer vibrations while replacing wheel bearings can cause an ABS sensor failure. If you are confident the sensor is good then the issue is either sensor wiring or the ABS module itself. Try testing the wiring continuity from the sensor to the ABS module to rule that out. If sensor tests OK and wiring tests OK then you have a faulty ABS module. Be sure to record and re-apply the module coding if you are going to swap it out. Another option is to send the ABS module out for repair as they usually can be fixed. I have fixed a few where the internal hair like wires break between the circuit board and the external connector but it is delicate work needing electronics repair tools and experience.
If one of the thinner than human hair wires has broken between the circuit board and the inside of the external connector then you have to cut open the sealed ABS module, remove some of the vibration dampening and moisture proofing gel coating, repair the wire and seal the unit up again. Or send it out to a pro shop for repair.
TPMS would be a completely separate issue as it has nothing to do with ABS.
@ctroxtell I suggest you try replacing that wire. You may not have detected a damage but it could be internal. As shown in my video above, the wire protection is very tough and can remain intact while the internal wires may have become severed.
