Transmission service cost
Old Apr 9, 2024 | 07:34 AM
Ron a8's Avatar
Default Transmission service cost
Good day ,
I called a shop here I'm Atlanta to inquire about a transmission service. They quoted me $1088.00 includes parts and labor, does that sound about right?
thanks Ron
Old Apr 9, 2024 | 08:28 AM
MP4.2+6.0's Avatar
Tech Guru
Originally Posted by Ron a8
Good day ,
thanks Ron
Even before price, need to be clear if it is just a fluid change, or fluid and filter. Filter means pan has to be dropped.
FWIW, I would do one filter change and at least TWO fluid exchanges. You only get about half the fluid out with a single drain--from measuring maybe 45% without pan drop, 55% with. So it takes two drains just to approach 75-80% overall cumulative fluid change. I bet shop was thinking only one fluid drain and fill and not sure on filter. Back in the day, Audi actually said 3x, which gets to 85-90% overall From having done it (see old posts), fluid remains visibly dirty on draining for second time. On third drain it visually is a lot better. So I sort of split difference but come out at two minimum, especially if never done before. You run it to operating temp in between the changes, then drain with pan on in later ones. I also shortcut the exact level setting of fluid (by temp) until final drain, which speeds up labor. Incremental fluid in ZF spec per drain is up to to a few hundred dollars at retail, plus labor charge for incremental work w/out pan drop.
Old Apr 9, 2024 | 09:19 AM
Ron a8's Avatar
this is what info they provided in the quote.
Old Apr 9, 2024 | 01:39 PM
dvs_dave's Avatar
AudiWorld Wiseguy
What engine/transmission combo are we talking here? Why are they proposing to put CVT type transmission fluid in? Do they even have a clue what they’re doing?
Old Apr 11, 2024 | 08:42 AM
the green amigo's Avatar
If using liquimoly fluid you need to use toptec 1800, as stated that is the wrong fluid all together.
Old Apr 15, 2024 | 05:09 AM
PGlock's Avatar
Good day ,
thanks Ron
My cost was $975 for parts and labor from a good shop in Columbus, Ohio. That service included dropping the pan and replacing all the seals, gaskets and bolts.
Lacucina_chef
Q7 MKII Discussion
20
Sep 21, 2022 07:58 AM
markradelow
Q7 MKII Discussion
10
Oct 8, 2021 05:38 PM
HoustonA5
Q7 MK 1 Discussion
Jul 27, 2009 10:01 AM
- thor ;-P
Feb 20, 2003 01:25 PM
TraderVic
Dec 11, 2002 06:10 PM
