Adaptive Air Suspension
Old Apr 9, 2024 | 12:01 PM
Johnboy28's Avatar
Default Adaptive Air Suspension
The other day the warning/indicator light for the adaptive air suspension illuminated and has stayed on steadily. If I activate the suspension on the MMI manually it works fine when I select lift or comfort. I have always had it set to comfort so not adjusting up and down at high and low speeds.
Any suggestion on what the problem might be? Is there an issue driving with the light on?
Old Apr 9, 2024 | 01:40 PM
dvs_dave's Avatar
AudiWorld Wiseguy
You need to scan it to see what the error code is.
Old Apr 10, 2024 | 08:38 AM
Johnboy28's Avatar
will do tomorrow.
Old Apr 12, 2024 | 08:54 AM
Johnboy28's Avatar
Originally Posted by Johnboy28
will do tomorrow.
attached is Autozone report
Old Apr 13, 2024 | 07:03 AM
Johnboy28's Avatar
Can i just ignore this light or do I need to get it serviced.
Old Apr 14, 2024 | 10:46 AM
Johnboy28's Avatar
Suggestions please
Old Apr 14, 2024 | 01:18 PM
91quattro's Avatar
I would not trust an Autozone scan on an A8 D3. See Post #2 - you should scan the car using VCDS. Having said that, this looks like it could be an ABS control module failure, but I would run a scan to be sure. I just went through this on my A8 which is nearly 20 years old. These cars have a Bosch ABS module that develops issues after a number of years and the error codes can be all over the place. The module can be sent out for repair to an ABS module refurb shop.
Old Apr 14, 2024 | 06:07 PM
Johnboy28's Avatar
Any suggestion where you could find a parts shop that could do this scan?
its a 2007 with 85,000 miles.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 15, 2024 | 04:46 AM
91quattro's Avatar
You are in CA correct? Lots of independent Audi shops with a VW-Audi specific scanning tool. Also available to you as VCDS, directly from Ross-Tech. If you will be keeping the car and doing any work on it, VCDS is a good investment.
Old Apr 16, 2024 | 06:09 AM
Johnboy28's Avatar
Problem solved. VW/Audi service test indicates its a rear level sensor.
emirtana223
Q7 MK 1 Discussion
Aug 27, 2023 01:23 PM
bosko86
Q7 MKII Discussion
Apr 12, 2023 12:16 PM
Aech
Q7 MK 1 Discussion
May 23, 2021 02:04 AM
Murt Ommukas
Jul 15, 2017 12:43 AM
Wowdi
19
Feb 21, 2004 06:53 AM
