2009 Audi Q5 lower control arm
So I took my 2009 Audi Q5 3.2L, V6 (in pristine condition with only 96k kms) to a local shop for basic service today (in the Vancouver area) and was told that I need to replace "left front lower control arm" because it's cracked - I was quoted $438 for the part and $159 for labour as well as $190 for the necessary wheel alignment afterwards (plus taxes and "shop supplies"). Does this sound like a reasonable deal? I've been doing a bit of research tonight and have some questions such as - shouldn't both the left and the right lower control arms be replaced at the same time? Trying to understand if I need lower control arms with or without ball joints? Thinking of ordering the parts online on partsavatar.ca but not sure which ones to get... Is $190 a good price for 4 wheel alignment?
Also, I was told that I need a new battery. They quoted $464 plus $160 labour (plus taxes). Is this a decent deal?
$400 for a control arm is going to be Audi OE pricing. Not sure anyone bothers with the expense of those original parts. Lemforder, Meyle HD, 034, most probably use some manner of cheaper third party replacements.
But if it is the bushing, the bushing alone can be replaced. Don't know if you have 65mm conventional or 75mm hydraulic bushings on the guide link; the hydraulic can eventually tear and leak. (looks like 75mm was a running change during MY10) The track arm has two bushings, one to the subframe, one for the strut fork.
So hard to say without more specifics of what specifically is defective. The Q5 workshop manual appears to lack the "should be replaced in pairs" statements I recall from the A4 manual.
$190, is that CAD? You'd probably had to ask around. But in the end the price is irrelevant if the place doesn't know how to do the job well. If you think they know how to do good work, that price is perfectly reasonable.
So I just called that shop and was told that it's one of the bushings which is cracked. I asked him (based on your recommendation) why can't the bushing be replaced instead of the whole arm and he said that "what if the other bushing fails later.. you'll end up having to pay again for the work plus wheel alignment". He (the service manager) didn't know if the bushing is conventional or hydraulic.
Money is tight at the moment so I'd rather not waste it on unnecessary car repairs. Wondering what to do now.. I guess I'll need to call a few other places locally to see how much they will charge. If one of the bushings is cracked on the left lower control arm - I wonder how long I can leave this situation without addressing?
Also, I found the control arm online for $160 Cad (vs $438 quoted by the shop for a non Audi part).. but the service manager said that customers can't bring their own parts. What a rip off. He said that they are not using Audi parts but "premium after market" parts.
This is what I found online..
https://partsavatar.ca/shopping-cart
Is this a dealership? A shop that won't let you supply parts, I'd probably skip.
https://www.ilcats.ru/audi/?function...00&language=en
That's the front suspension. The guide link is the curved lower, part 7. You see it changed Jul '09, when the bushing, part 8, was changed from 65mm conventional to 75mm hydraulic. Yours is conventional.
But it sounds like it's the forward track arm (straight), part 1, they are talking about? We see, part 1, as well as the ball joint 20 and ball joint nut 6A, all rolled from one combination to another starting Nov '08. So the mo/yo of your vehicle build would be relevant to getting the correct arm if you went whole arm replacement. The rev D arm has replaced the rev C arm, and Audi catalogs that as the replacement for the B arm as well. But that brings up the question, if you have the B arm and the E ball joint, and go to replace the B arm with a D arm, do you need to replace the E ball joint with the F ball joint? Off the cuff guess would be yes.
$42, https://www.genuineaudiparts.com/oem...ing-8k0407182b (replaced rev A)
$92, https://www.genuineaudiparts.com/oem...ing-4e0407181b
$260, https://www.genuineaudiparts.com/oem...arm-8k0407151b
$313, https://www.genuineaudiparts.com/oem...arm-8k0407151d (replaced rev C)
So to be honest, for the bushing parts and the labor to press/install, probably same enough to just buy an actual Audi OE arm. Clearly, if it's the older arm, that's better than the newer arm. I assume your prices are CAD rather than USD, so my numbers are probably higher for you.
