Inner Tie Rod Replacement - Help
The workshop instructions are for an electrical-mechanical steering rack but I will check again to make sure it applies to my 2014. Perhaps there is more than one non-hydraulic version.
Lastly, I am thinking I should add a little grease to the rack while it is exposed. Do I need the VAG specific steering rack grease or can I use a generic grease? It looks like the steering rack grease is also specified for the inner tie/track rod ball but I have no idea what "type" of grease it would be.
I know I need to get my specific manual rather than the all inclusive China version, but here is the section of the manual in question:
On the grease, I find it interesting that it's different for the two ends. No doubt reflecting the sliding surface vs the gear surface. G052168A1 driver end, G052197A1 passenger end. Though apparently that distinction was not important enough to retain after factory production ended. Now it's just G052168A1 both ends. At least it's only $15, well for 10g. "♦ To grease the rack, only use Steering Gear Grease ."
I think you are onto something about the Audi technical writer just copying and pasting from the hydraulic steering rack instructions. I will turn the rack full left and full right tomorrow just to make sure I am not missing anything, but you would think that any flats on the rack would be fairly close to the tie rod knuckle/ball. And yeah, left (driver's) side of the rack is just a rod. I did see somewhere that 2 different greases were called out for each side of the rack, which makes some sense. And I did come up with G052168A1 as the Audi steering rack grease too. Do you think I would be safe picking up some "steering gear grease" from my local O'Reilly's? Q5 is my only car, so the O'Reilly's in town is my only option if I want to finish the install tomorrow.
Here is the ECS Tuning link for the grease:
Search SiteSearch steering rack grease - G052168A1 - Bellows grease - 10 grams (G 052 168 A1) (ecstuning.com)
Comment in another thread by someone on the steering gear grease, "The steering rack grease (part #: G 052 168 A1) is just a yellow-ish grease and goes on the gears (covered by the boots). ...it gets dry and clumpy with age". Looks like from another thread on BMW, that is also a yellow soft grease.
I don't know anything about that grease, no idea what a non-Audi alternative would be. Seems it's strictly for lubricating the rod, not for "packing" the boot like you would for an axle.
Relevant video - youtu.be/6E0BHajkt5o there's a link to the grease they used in the description
Thanks for the links!
Update: I can confirm that there were no flats on the steering rack for counter-holding and it was not necessary. The rack did not rotate as I was loosening the knuckle of both inner tie rods.
The electric rack track rod (aka tie rod) is 4G0 423 810 A, Lemforder part 35740 01.
It's not so much about the B8.0 vs B8.5, but the rack tech.
I take it from the catalog pics, the upper is the 35740 part for the electric rack and the lower is the 35705 for the hydraulic rack?
