07 A8 D3 Oil Control Valve Testing Ohms?
Old Apr 17, 2024 | 12:58 PM
pelletman's Avatar
Default 07 A8 D3 Oil Control Valve Testing Ohms?
Anyone know what the value should be? When I test it it starts in the mid sevens and goes to about 6.6. Is that within specs?
Thanks!
Old Apr 20, 2024 | 11:50 AM
pelletman's Avatar
Nobody knows this spec!? In any event I cleaned and tested by putting 12V to it and it worked, so I put it back in but haven't started the car yet so I am not sure if it cured my problem
Old Apr 20, 2024 | 03:14 PM
dvs_dave's Avatar
AudiWorld Wiseguy
How about nobody knows what you’re talking about? What’s this “oil valve” that you’re generically referring too? Care to give us its proper name or describe what it’s for?
Old Apr 20, 2024 | 05:52 PM
91quattro's Avatar
+1 what dvs_dave said. Not enough info. Let's start with where in the engine it is located? Do you have an Audi P/N?
Old Apr 22, 2024 | 12:58 PM
pelletman's Avatar
I cleaned and tested it and the car seems to be running better and throwing no codes (for that anyway) One on each side of the engine, towards the rear. Car is A8 4.2 2007. Looks exactly as pictured at link below. Thanks!
Amazon Amazon
Old Apr 22, 2024 | 03:42 PM
91quattro's Avatar
Cam VVT solenoid
Old Apr 23, 2024 | 10:41 AM
pelletman's Avatar
Yeah they call it a whole bunch of things
https://parts.audiusa.com/p/Audi_200...6E109257P.htmlControl Valve Solenoid. Engine Variable Valve Timing (VVT) Solenoid.
Incl.Oil Control Valve. Solenoid to adjust camshaft Timing.
Fits A4, A6, A8, R8, RS5, S6, S8, TT RS
A4. A4 Cabriolet. A6. A8. Beetle. Jetta Wagon. Jetta; From 2/19/13. Jetta; To 2/18/13. Passat. R8. RS 5. S6. S8. TTRS.
Variable Valve Timing Control Solenoid - Repair or Replace
A faulty variable valve timing control solenoid, or spool valve, can result in a check engine light accompanied by engine hesitation and pinging under acceleration. If your 2007 Audi A8 needs attention, contact our service department.
59 people have looked at this part recently
Old Apr 28, 2024 | 01:42 PM
pelletman's Avatar
OK, just to update in case anyone else is experiencing the same problems, I also have an older thread asking about this problem with the codes, I cleaned the VVT solenoid with MAP sensor cleaner, tested it, put it back in and the car seems to be running fine, no codes, I put about 20 miles on it today. Now onto the other issues.....
 Pouria Savadkouei
 Michael S. Palmer
Suruki
A4 (B8 Platform) Discussion
Jan 25, 2017 07:39 PM
wasya152
Dec 30, 2003 05:57 PM
borden
Feb 7, 2003 10:30 AM
Innovator
Jul 21, 2000 10:45 PM
