A6 / S6 (C6 Platform) Discussion Discussion forum for the C6 Audi A6 produced from 2004-present and Audi S6 produced from 2007 - 2011
Wheel bearing recommendations?
Old Apr 18, 2024 | 07:34 PM
B5A4Dave's Avatar
Default Wheel bearing recommendations?
The new Avant arrived a couple days ago, it's in pretty good shape but needs a few things...
First off, one or both of the rear wheel bearings are bad, bad enough to make driving it not really fun...
Does anyone have thoughts on quality of various brands? SKF? Febi Bilstein? Obviously VW/Audi is good but they're so expensive
Thanks!
Dave
Old Apr 19, 2024 | 09:03 AM
A6Gary's Avatar
Assuming your Avant is a A6 C6, I have used the SKF bearings for a replacement on the front. Audi parts are not made specifically by Audi Ag, so probably SKF makes the bearing for them as an OEM part (with the four rings that increases the price). Note that for a rear bearing replacement, you will need to drop the exhaust to access the bearing (per the Bentley Repair Manual).
Old Apr 23, 2024 | 10:20 AM
B5A4Dave's Avatar
Thanks for the info, I went with SKF for the rears, figure I'll do em both at once...it's noisy enough that I can't really tell which one anyway. $339 for the pair (with hardwar) from ECS
I watched this AutoDoc vid of a C6 RWB replacement...looks like it's a FWD TDI though...no center lug to the rear CV. I can't imagine that it's that much more complex on a quarttro since the hub and bearing cartridge both come out on the front side...if anything the CV might make the 4 12mm triple square bolts a little more tricky to get to...
TCP
May 23, 2026 11:05 AM
Kato
May 14, 2013 09:49 AM
98'2.8
Jan 16, 2012 04:09 PM
Chalfont
Dec 11, 2007 03:43 PM
laterskater
May 23, 2005 07:30 AM
