ABS Module Replacement on 2013+?
Old May 1, 2024 | 02:52 PM
mthew_m's Avatar
Default ABS Module Replacement on 2013+?
Hello all,
Have a 2013 Q5 2.0T (US, so Quattro + ZF8) with a G201 ABS Module fault code. I see resolution to this for 2009-2012 cars, but, not for 2013+. I reached out to Module Masters to see if they would rebuild it, and they told me they could not. What's the fix here? A shop quoted almost $3,000 to install a new one, which is definitely a no-go. I have access to a Ross Tech cable - is there anything that can be done, other than shelling out huge money for a new one?
Old May 4, 2024 | 01:32 AM
SMac770's Avatar
Community Builder
Community Influencer
G201 brake pressure sensor is internal to the J104 ABS control module, which is mounted onto the N55 ABS hydraulic unit. For B8, Audi says to never separate the two components from each other. They changed that tune for B9. But I don't know if other changes were done for the B9 unit to better enable that shop instruction change. I don't know why the B8.5 would represent any change in corrective options compared to B8.0. I'd expect you'd just source a used unit of the same p/n, have it installed and adapted, carry on. People have replaced their ABS unit to be able to enable auto-hold or ACC, so it's not an impossible task.
US MY13 would have used 8R0614517CE (8R0 614 517 CD + 8R0 907 379 AK) through Nov '12, then 8R0614517CG (8R0 614 517 CF + 8R0 907 379 AL) for Dec '12 onward. What's curious is a new CE is $2800 msrp, while a new CG is only $2000. But you can still get that new OE for $2300 and $1650. Still a lot. Which is why I couldn't see anyone bothering with a brand new one. As for using a later MY Q5 unit, should you find one, such as this rev DC unit (rev DB N55 + rev AS J104) https://www.ebay.com/itm/235546682430 I don't know. You might search around at other B8 threads (A4, A5, Q5) re ABS unit replacement and see if others have used later year units without issue.
Old May 5, 2024 | 04:48 PM
alms_lefko's Avatar
https://www.audiworld.com/forums/q5-...3061481/page3/
See my ABS saga above - I had pressure sensor issues too - I spent $35 on a used one. Re-coded with VAGCOM. Works 100% since.
q7enthusiast
Q7 MK 1 Discussion
Jul 7, 2016 12:40 AM
forumaic
Jun 26, 2010 12:43 PM
MetalMan
VAG-COM Discussion
Jun 9, 2010 07:32 PM
InnyAudi
Oct 17, 2007 06:48 PM
Dr. Jitter
VAG-COM Discussion
Jun 23, 2005 02:10 PM
