a8 4.2tdi 2008 want start engine
Old May 5, 2024 | 05:23 AM
mdwalter's Avatar
Default a8 4.2tdi 2008 want start engine
To straighten the muffler I removed the rear bumper and for convenience I also removed the battery, but when I replaced the battery I forgot to attach the red/white cable and a red cable that goes to the fuses on the rear right side (where there are none the battery), the car was running then at a certain point everything started to wobble and from then on the engine won't start anymore. Now it says abs/esp anomaly, the indicators and he outside work but in the dashboard they don't. If I turn the key to start I hear a click of a relay under the steering but the starter motor doesn't move, I tried to code the battery but nothing. I looked around and they say the error: 46-Central Conv. -- Status: Cannot be reached 1100
it means that the fuse/relay box above the battery cannot be reached, but they are connected.....anyway here are the errors:
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5C-Lane Maintain. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100(this was already like this)
I hope you can help me
and sorry for my english
P.s. obviously when I coded the battery I then reset the errors
Thank you!!
lazuviniciu
A4 (B9 Platform) Discussion
Jun 11, 2023 01:44 AM
AndrewWake77
2.0T FSI Discussion
Apr 8, 2022 02:32 PM
El Nino Loco
VAG-COM Discussion
Dec 28, 2020 12:45 PM
nathanwind
17
Jul 6, 2013 03:31 PM
tzr1
VAG-COM Discussion
9
Mar 20, 2011 02:29 PM
