Ignition Lock Defective
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0328
Revision: 00002001 Serial number: 0128915032
Coding: 0126023A207A749404B0053200000000
Shop #: WSC 06335 000 00000
VCID: 045285B07E196577091-8050
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000240815
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Serial number: 0123456789ABCDEFGHIJ
1 Fault Found:
00166 - Access/Start Authorization Switch (E415)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 138287 km
Time Indication: 0
Date: 2024.05.03
Time: 18:13:26
https://www.audiworld.com/forums/q5-.../#post24616233
https://www.audiworld.com/forums/q5-.../#post25343851
PDF attached Removing and installing entry and start authorisation switch -E415-
Some other procedures are involved that I am not familiar with. Do you also have these?
- Removing and installing dash panel cover (driver's side).
- Removing and installing impact damper.
- Removing and installing dash panel vent.
Regards,
Scott
https://audi.snapon.com/SpecialTools...x?itemId=80163
But sometimes the tool can be found elsewhere by its tool id, often chinese knock offs on Amazon or such. At least that tool is cheap.
Regards,
Scott
