Any 2013 Audi Q5 2.0T Rear main seal replacement video
Old May 25, 2024 | 07:31 AM
truepet4's Avatar
Default Any 2013 Audi Q5 2.0T Rear main seal replacement video
Hi I have logged 119000 miles on my Q5. Recently noticed lot of vibrational noise and after smoke test, it seemed like the Rear Main seal is broken. I did confirmed with a mechanic.
The problem is, it is going to be too expensive to get it replaced from a mechanic (quoted 3k).
The part is about $150. I am also not getting a great value on tradein for a new car (~3k value).
I wanted to DIY rear main seal replacement on my Q5.
Is there a well documented video/ tutorial that can help me achieve at home RMS replacement?
Thank you.
Old May 25, 2024 | 12:34 PM
silver_tt's Avatar
Unlikely if you mean the entire procedure end to end. Replacing the RMS requires removing the transmission (or the engine) on a 2.0T so is a major job.
How do you know it’s the RMS? If it is that bad you should have oil leaking and a vacuum leak. I have 130K miles still in the original RMS which is the old design. If your PCV diaphragm tears it won’t throttle down the vacuum from the intake enough and this can cause the RMS to get sucked in at the seal.
Old May 25, 2024 | 04:32 PM
SMac770's Avatar
Community Builder
Community Influencer
One, don't bother starting such a level of task without the workshop manuals in hand, and having read through them to see what all is involved when the task is done correctly. https://www.audiworld.com/forums/q5-.../#post25902766
Two, as mentioned, you have to drop the transmission to access the RMS. The other option, pull the engine, is not simpler. So this DIY is very much on the very involved project level. The actual replacement of the RMS itself is simple, but is easily screwed up if you do not respect the handling of the seal during the installation.
https://www.audizine.com/forum/showt...1#post14289197
Is it possible? Sure. Is it simple? Not in the slightest.
Old May 26, 2024 | 02:33 PM
Windows95's Avatar
$3k seems too high. Should be closer to $2k for RMS.
A7 Competition
Audi A5 / S5 / RS 5
Sep 6, 2021 09:26 PM
raj99
Q5/SQ5 MKI (8R) Discussion
Nov 22, 2015 01:07 PM
Dr944S2
Audi 100 / A6 (C4 Platform)
Nov 10, 2013 02:12 PM
00zero
Audi Original "S" Cars
Jun 14, 2004 03:49 PM
absolutcq20v
Jan 28, 2004 03:34 AM
