AMI / Aux connection conundrum
I’ve recently fitted one of these 10.25” android screens to my Q5 and everything seemed to be good until trying to play audio. The system needs the source to be set to external aux which should have been achieved by connecting the provided AMI to 3.5mm jack adaptor to the Ami port and then to the audio out coming from the new screen BUT after plugging in everything the source menu says ‘AMI no device connected’ and it’s driving me potty. Below are all the things I’ve tried:
1) checked all connections multiple times - all good
2) ensured everything is in the correct place - all good
3) checked no connectors are loose, damaged or broken - all good
4) checked all pins to make sure none are squashed, bent or missing - all good
5) Ami cable has a 1k ohm resistor between pin 21 and 22 which should auto-select aux when plugged in (which it doesn’t)
6) Tried another Ami to male 3.5mm jack also didn’t work
6) checked continuity of all the cabling back to the new screen - all good
7) checked all settings on both new system and original MMI - all good
8) checked all fuses on both car and new system - all good
After all this and still no joy. But now the big twist! I reinstalled my old Apple CarPlay module which is connected to the original 8.8” display and after making all the connections the external aux connection was grey…until I plugged in the same Ami cable and it switched on and everything worked 100% fine.
Has anyone got any ideas as it’s driving me bananas. Have spent so many hours trying to troubleshoot this issue but now i’m stuck!!!
I’m wondering if I need to enable the green menu which currently doesn’t work on my car and then properly switch on the aux input but why does my old system switch it on and the new one not!
Please please helppppppppp. Thanks
So "what's different"? It's all the same except the "man-in-the-middle" harness you install between the factory harness quad-block plug and the J794 (going to assume this is an MMI 3G config)? I don't have an AMI AUX cable to test, but I assume the only wired pins on it are 1 to tip, 2 to ring, 3 to sleeve, 4 is the shield, then resistor across 21 to 22. 21 goes back to T12y pin 6 (orange); 22 goes back to T4ap pin 4 (brown). The ground on 22 is shield wrapped with iPod detect on 16 (orange), USB data+ on 17 (blue), and USB data- on 18 (green). These four go together to the HSD jack. Unclear what 9 (violet, to T12y pin 5) is for. J794 info says unassigned.
Assuming the third-party devices are not interacting with the HSD jack which connects 22 back to the J794 (the yellow one), that path is likely unchanged. And if it's the same AMI cable, that's unchanged. So what changed? The connection from green pin 6 on the J794 to pin 21 on the AMI port.
Take the working config, unplug whatever is directly plugged into the J794, unplug the AMI cable on the AMI port, then test resistance value from green pin 6 on the whatever plugs into the J794 to the pin 21 on the AMI port. Then swap out for the other materials, test again. Is there an issue getting pin 21 to pin 6, open circuit, high resistance, flaky consistency, etc.
Thanks
i traced the green pin 6 wire as it splits mid-loom and followed that up to one of the connectors going into the screen. This also had good continuity and was not high resistance.
This is driving me to madness. I might just reinstall the old CarPlay box and send this other one back.
I assume the hideaway box solution uses a similar manner of intermediate harness? If you look at the routing of the green 6 wire on both intermediate harnesses, do they appear to do the same thing?
I don't really catch what Ringsby is saying he did in his last post, but you might review the thread: https://www.audizine.com/forum/showt...1#post15062502
Another difference though is the hidden box tapped into the canbus power by piggy-backing a connector on the back of the ac control panel whereas the android screen version is routed into what I think is the body control module (remove glovebox and it’s on the side of the centre console with two connectors. One red one black - it piggy-backed into the red connector)
Any other ideas before I get the cutters out and chop that wire in a place where I can easily splice it back together should that not make a difference?
Many thanks for your help as well
Now bashing head against wall as it seemed all too easy to install and for it to just work. While I was out measuring the resistance earlier I checked every part of the install again for the umpteenth time and all seems correct
