Is main seal something you would ever DIY?
Check your crankcase vacuum with a manometer and make sure you replace the PCV before the diaphragm becomes compromised. Crankcase vacuum above spec can cause the RMS to be sucked in... I have the old style on my 2014 and at 130K+ miles it doesn't leak at all.
MLB era transmissions, from Audi's SSPs:
ML311-6F (0B1) was ~ 68 kg (150 lbs)
ML311-6Q (0B2) was ~ 79 kg (173 lbs)
ML351-6F (0B3) was ~ 77 kg (170 lbs)
ML451-6Q (0B4) was ~ 86-88 kg (190-194 lbs)
DL501-7Q (0B5) was ~142 kg (313 lbs)
AL651-6Q (0B6) was ~ 136 kg (300 lbs)
AL551-8F (0BK) was ?
AL551-8Q (0BK) / AL951-8Q (0BL) were 141-146 kg (311-322 lbs)
AL551-8FE (0BW) was ~ 150 kg (331 lbs)
AL551-8QE (0BW) was ~156 kg (344 lbs)
Don't know about the 0AW CVT. The prior gen 01J CVT was ~ 88 kg (194 lbs).
So quattro added around 10kg for the 6MTs, but only about 6kg for the ZF8s. The 0B5 and 0B6 were only quattro. The 40 kW e-motor in the 0BW for the hybrids (HEV, not MHEV or PHEV) added 10-15 kg.
Audi over the past 10 years goes out of its way to not document specifications, it would appear.. Starting with the MLBevo SSPs, Audi doesn't document any weight of any thing. So for the second gen ZF 8HP (0D5, 0D6, 0D7) and the second gen DCT (DL382; 0CJ, 0CK, 0CL, 0HL), don't know offhand.
vwatj.com lists the DL382-7F (0CK) as 116 kg (255 lbs). That's FWD; the quattro tend to run ~10kg more on the ZF stuff. So assume DL382-7A (0CJ) and DL382-7Q (0CL) around 125 kg (275 lbs)?
What do you think is a reasonable price to do the job for an indy?
